Anyone tried this stuff
3 replies to this topic
#1 jumptrout
jumptrout
  • 1,382 posts
  • Flavorite Brew:Coors Light
Posted 08 July 2013 - 10:32 AM
http://biggeekdad.co...rproof-coating/
#2 DurhamAppliance
    Sho' Nuff Chozin
  • 5,781 posts
Posted 08 July 2013 - 11:09 AM
Looks like pretty amazing stuff. I haven't tried it but I will soon, thanks to your heads up. I would coat all of my tools. Just imagine, parents could coat sheets on the bed of a bedwetter. Apparently the stuff isn't toxic to the skin since they showed it being used on a shirt. Applications are endless.
www.DurhamApplianceThrift.com
#3 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 08 July 2013 - 09:58 PM
click on picture
d0c957a0-3b08-4a7d-8102-eaeac18d11db_300
http://www.rustoleum...et/neverwet-kit
About NeverWet - Homeowner Use
Rust-Oleum® NeverWet is a two-step product system designed to create a moisture repelling barrier on a variety of surfaces. It is suitable for use on metal, wood, aluminum, galvanized metal, PVC, concrete, masonry, asphalt, vinyl siding, fiberglass, canvas, most plastics and more. Read the NeverWet instructions for more information about application and use.
  • Not intended to be applied to electronic devices or clothing
  • Sprays clear and dries to a flat light haze
  • Durable formulation, ideal for indoor/outdoor conditions
  • Dries fast — 30 minutes to touch
For Best Results
NeverWet Top Coat should be reapplied when water no longer rolls off of the surface.
NeverWet Instructions:
http://www.rustoleum...structions.ashx
NOTE: NeverWet can be used on fabric, leather and canvas
however; NeverWet will dry to a flat, milky haze and may change the appearance,
especially on dark colored items.
Test in an inconspicuous area before applying.
Treated surfaces will lose superhydrophobic properties if exposed to detergents, soap, oil, solvents or high pressure water.
Certain solvents, alcohols and soap/detergents will cause the surface of the coating to lose superhydrophobicity.
NeverWet should not be used on electronics.
#4 DurhamAppliance
    Sho' Nuff Chozin
  • 5,781 posts
Posted 08 July 2013 - 10:59 PM
Hey... they didn't say anything about injesting it. Since we're mostly made up of water, the reaction could be quite fascinating
