72944
Whirlpool Duet Sport Washer troubles
7 posts in this topic
I pressed the PAUSE/CANCEL button with about 5 minutes left in the final spin cycle.  The washer stopped and the door unlocked.  After putting in a new load of laundry I pressed the power button and it powered up normally, but when I pressed the START button it beeped once and then powered off.  I selected all the other cycles, including DRAIN/SPIN, but the same occured for all.  I unplugged the machine for several minutes and tried again, but still it just powers off.  I did a diagnositic test and got and F01 code.  Any ideas?
Model number??
I think this is it:
WFW8300SW04
I slid the CCU from its mount (without disconnecting wires) and hit a couple of times firmly with my knuckles, then reattached it.  I pressed the power button and then the start button and it started working.
Replace the control board, you'll be happier in the end.
