Frigidaire Stove Model # FEF379ACF (Manual clean only)
1 reply to this topic
#1 Waneewek
Waneewek
    Sōhei
  • 214 posts
Posted 09 July 2013 - 04:46 PM
I have a Frigidaire stove model # FEF379ACF with a self clean function that doesn't work.  When I set it to clean and set the time for 2 or 3 hours the door locks, but only the bottom bake element comes on.  The broil element never gets the 240 volts.  I can set the oven to broil and it works fine, but not in the clean function.  Of course the tech sheet is gone and I have no wiring diagram.  Does the door switch come into play for the clean function?  I checked the door/light switch and I think it is bad, and no longer available.
Thanks for your help,
Wan
#2 Spannerwrench
Spannerwrench
    Mutsuhito
  • 1,100 posts
Posted 09 July 2013 - 05:23 PM
You shouldn't be using the self clean feature anyways. It can and will only lead to problems.
"Suds are not good"
"Occam's Razor 'the simplest answer is most often correct'"
