Kitchenaid KSSC48FMS 02 Does not cool fridge, freezer ok
2 replies to this topic
#1 Russ M
Russ M
  • 1 posts
Posted 10 July 2013 - 05:27 PM
Freezer is cooling fine.   Did all the standard troubleshooting: cleaned coils, cleared air flow (emptied fridge), did a full 10min power reset.
What explains the freezer working just fine and the fridge half of the side by side to stop cooling?  Are they separate systems?
Thanks!
#2 Spannerwrench
Spannerwrench
    Mutsuhito
  • 1,076 posts
Posted 10 July 2013 - 05:35 PM
Is the evaporator fan behind the rear panel in the freezer running?
Is the air damper at the top left corner of the fresh food section open?
Is there frost buildup on the return vent in between the two compartments?
<p>"Suds are not good"<br>
"They write directions for a reason"<br>
"Make sure you're using it right before you say it's not working correctly"<br>
"If if has a Diagnostic Test Cycle, Run it before and after you fix it!"<br>
"Doing the same thing over and over again and expecting different results is insane"<br><span style="color:rgb(0,0,0);"><span style="font-family:'Helvetica Neue';">"For every complex problem there is an answer that is clear, simple, and wrong."</span></span></p>
<p><span style="color:rgb(0,0,0);"><span style="font-family:'Helvetica Neue';">"Occam's RAZOR </span></span><span style="color:rgb(56,57,57);font-family:Montserrat, sans-serif;">'the simplest answer is most often correct'"</span>
#3 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 10 July 2013 - 06:55 PM
... Freezer is cooling fine.
... fridge half of the side by side to stop cooling
post temperatures
