ADF
Whirlpool French Door GI5SFAXVY02 won't switch from Ice to Water...
4 posts in this topic
Fridge runs great, but cant get any water.  Ice comes out no problem, I replaced the touch pad but still won't work. I know it's a board but not sure if it's the dispenser board or main control board. Also the fridge temp will go down, but not back up....
ADF
Put it into test mode and see if you're getting 120vac at the dispenser valve coil when you depress the flapper:  http://appliantology.org/files/file/1052-whirlpool-7gi5fsaxv-gi5fsaxv-gi5fsaxv-7mi2569ve-mfi2269ve-mfi2569ve-french-door-refrigerator-tech-sheet/
If you're getting voltage to the valve, then either a frozen fill tube or bad valve:  http://www.repairclinic.com/PartDetail/Water-Inlet-Valve/67006322/1187201?modelNumber=GI5SVAXVB02
It's not that it won't dispense, I can't even get the button to light up.  Everything else on the touch pad works, just not the water button.  Put in new touch pad and water still won't light up.  I know it's a board just not sure if it's the main board in the back or the dispenser board....
GI5SFAXVY02
My eyesight isn't as good as it once was blink.gif (see RegUS_PatOff http://www.youtube.com/watch?v=oPAY2LsKVEw)
but, from here, it looks like your model number may be
GI5FSAXVY02
... I can't even get the button to light up....
not mentioned in original post
Does the Ice Fan work ?
(Main Board)
LED Dispenser Lights are controlled by
http://www.repairclinic.com/referral.asp?R=154&N=1481129
Main-Control-Board-W10162500-01265727.jp
Any part ordered from RepairClinic can be returned for a refund (less shipping)
including installed electrical parts
