brianl0646
Question about inner bake element in GE Monogram pro range ZDP30N4HSS
1 post in this topic
There are 2 bake elements in the oven on this range. I turn it on and the outer element gets red quick and the inner element gets hot instantly (I have burns to prove it) but does not turn red. Do these serve different purposes? And maybe run depending on temperature that is set? This was called out as defective on a home inspection but I tend to believe since they are 2 separate elements they are designed to do 2 different things. I would appreciate any help here.
Thanks much,
Brian
