lilhalls
WHIRLPOOL DRYER LCR7620KO0 flame will not stay on
16 posts in this topic
Help ! here are the symtoms
  1. ignighter glows
  2. flames come on
  3. after about a minute it stops
  4. only way to get flame back on open door and resset time
checked:
  1. high llimit
  2. high low sensor
  3. flame sensor
could it be the gas coils?
any help will be appreciated- 4 kids and no dryer is not fun.
... LCR7620KO0
... after about a minute it stops
... could it be the gas coils?
maybe LGR7620KQ0 ?
how long have you waited ?
Does the Ignitor then again glow, but no Flame ?
Possibly coils but not likely. Usually coils fail to to open the valve, I haven't seen them fail while the flame is on. You need to see what is shutting down the burner. Monitor high limit thermostat and see if it opens when flame goes out, when it cools off it will close again. Also check for 120 volts to burner assembly when flame shuts down. I think you will find that something is cutting the power off the burner assembly.
1 person likes this
Try it with the vent hose NOT connected. If it works normally your vent is plugged up and needs cleaned out. I would replace the coils while you are at it.
Nick
3 people like this
Ok I disconnected and it seem to run fine. I replaced and cleaned the vent line. When I reconnected it made it through half a cycle and now the gas valve does not release could it all be related to the valves?
... Ok I disconnected and it seem to run fine.
... could it all be related to the valves?
seems to be related to the Vent
Dryer Vent 4" diameter
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
Check / clean the Dryer Vent
$ 3.99 sometimes on sale for $ 2.99
the temp seems fine. I watched the flame run for about 20 mins and then left the dryer running. When I came back the flame was out and it would not relight. the ignighter would light but the gas valve would not release. Its almost like it cools down and then it will work for another 20mins?
... I came back the flame was out and it would not relight.
... the ignighter would light but the gas valve would not release.
how long did the Ignitor stay glowing ?
90 seconds
90 seconds
about the correct time for the Flame (heat) sensor to detect that the Ignitor is up to temperature,
The Flame Detector Switch should then open the Gas Safety Valve ...
Symptoms of weak Gas Valve Coils
1 person likes this
ok I am going to purchase the coils before my wife thows me out with the dryer
thanks for the help!!!!
... flames come on
... I watched the flame run for about 20 mins
How long does the Flame stay lit ? ? ?
The valve coils are failing from thermal fatigue. They'll work a cycle or two then stop from heat deformity.
Replace the coils and move on.
1 person likes this
ALL,
THAT WAS IT, I REPLACED THE COILS LAST NIGHT AND ITS WORKING. THIS MADE MY WIFE VERY HAPPY AND YOU KNOW WHAT THEY SAY ~~~~HAPPY WIFE HAPPY LIFE !!
THANK YOU FOR ALL THE HELP.
1 person likes this
Good job!
And thanks for letting us know how it turned out.
