Maytag MLE2000ayw
2 replies to this topic
#1 gcw1
gcw1
    Yamabushi
  • 80 posts
Posted 15 July 2013 - 08:53 AM
Maytag MLE2000ayw won't start. you push the start button it will drain until you release the button. The customer brought in the machine control board and on the back it was burnt around connection P-3 !,2,3.leading to P-4. Trying to save money he wanted to just buy the board and replace himself.
I have never seen it burn out in that spot before and it advised him it should be checked out.
In saving $75.00 service call he came and got the board put it in, 1 hour later called and said he hit the start button and heard a loud spark, brought the new board back and same burnt spot.
Has anybody run into this before? It looks like that it comes from the timer. Thanks!!
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 15 July 2013 - 09:18 AM
post pictures (somewhere) of both sides of the Board
#3 Spannerwrench
Spannerwrench
    Mutsuhito
  • 1,131 posts
Posted 15 July 2013 - 10:41 AM
I don't know if this helps or not.
Failed resistor guide.
http://appliantology...-failure-guide/
"Suds are not good"
"Occam's Razor 'the simplest answer is most often correct'"
