Kenmore tumble washer 41747102700 bearing problem
41747102700 bearing loud
5 replies to this topic
#1 pastorjoelcm
pastorjoelcm
  • 8 posts
Posted 15 July 2013 - 09:06 PM
Hi, do you have a service manual for 41747102700 kenmore washer?  I have a friend whose washer was making a really loud noise & started to leak as well.  Now it is not working at all.  They think it is the bearings.
Do they sell just the bearings or do you have to replace the whole back including the bearing?
Any tips or thoughts before I jump into this?
Thanks.
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 15 July 2013 - 09:49 PM
... washer was making a really loud noise
... They think it is the bearings.
OR it may be a broken Spider
some info:
http://fixitnow.com/...igh-speed-spin/
http://appliantology...ry-41739012891/
http://appliantology...ive-5995369211/
#3 JJ Surfer
JJ Surfer
    Sōhei
  • Appliantologist
  • 154 posts
  • Flavorite Brew:Sierra Nevada pale ale
Posted 16 July 2013 - 01:50 AM
If its leaking then the tub is probably damaged. Most likely needs new basket, back half of tub and front half as well if its been rubbing, in other words...if not in warranty it's time for a new washer
#4 pastorjoelcm
pastorjoelcm
  • 8 posts
Posted 16 July 2013 - 01:58 PM
I actually looked at the machine today.  No leaks.  Noises were a thump and squeal as you turn.  I completely took apart the machine even taking apart the front and back of the tub.  I hit a stand still when trying to separate the back from the basket.  I tried a wood block and a rubber mallet and the thing did not budge at all.  I ended up wailing on it as hard as I could and got it to move some but I cannot get the shaft through so I can examine the spider to see if it is bad or not.  I was able to notice an obvious wobble as I turned it and etches in the tub where the screws are hitting the tub wall.  I'm pretty sure its' the spider but not 100% til I can see it.  I would hate to toss it after all that work if it is just the bearings.  Any tips on getting the last part of the shaft through.  I had to hit it so hard that I believe the edges of the shaft have miss-shapen some.  Thanks
    Shōgun
  • Master Samurai Tech
  • 30,624 posts
Posted 17 July 2013 - 06:38 AM
This tells you the corrosion has progressed to such an extent that you can't even get the parts separated.  This is exactly why professional Appliantologists will always replace the inner basket and outer drum as a set.
Outer drum with bearings:  http://www.repaircli...er=417.47102700
Rear-Drum-with-Bearing-131525500-0114267
Inner basket:  http://www.repaircli...er=417.47102700
#6 pastorjoelcm
pastorjoelcm
  • 8 posts
Posted 17 July 2013 - 08:10 AM
Thanks for the advice.  I guess you can't win them all.  The upside is that I now know how to take apart a front loader and get to the different parts.
