dryerman45
FRIGIDAIRE DRYER INOP
6 posts in this topic
SAMURAIS,
I have a frigidaire dryer model# AEQB6400FS0.When you turn the power button on, the display and everything up front is working.When you go to start it you hear a relay click on the control board but drum doesnt turn and of course nothing elese happens.The timer does count down as if it were running.I checked for error codes according to the tech sheet entry and it comes up with an ''E9E''.I dont know what this means as it is not listed in the error code table in the tech sheet.Maybe bad control assy.Before I turn into a PCM please help
Thank you
SAMNAREA
The error code E9E indicates that low voltage is being detected at the control board of the dryer.
This could be caused by the following:
1) The electrical power supply to the dryer is bad. Check the dryer outlet for proper voltage.
2) Unplug the dryer and check the wiring of the dryer outlet plug. A loose wire on the terminal block could cause this problem.
3) If you are able to safely access the control board in the console, check the red wire that connects to the heater relay on the board. (NOTE: The dryer should always be unplugged when accessing internal components.) A loose wire or burned connection in this area could result in this error code.
4) A failed control board could cause this problem.
5) Make sure all connections have been checked throughly before replacing the board,
Edited by tpoindexter
Thank you for the help.It turned out to be the main control board up front of unit.I did check voltages at wall ,and at terminals before and they were fine
SAMANERA
Domo for letting us know, SAMANERA!
One followup question just to clarify for future readers:
This is the main control board:  http://www.repairclinic.com/PartDetail/Main-Control-Board/134557200/1170676?modelNumber=AEQB6400FS0
Main-Control-Board-134557200-01020806.jp
This is the user interface board:  http://www.repairclinic.com/PartDetail/User-Control-and-Display-Board/134556500/1170673?modelNumber=AEQB6400FS0
User-Control-and-Display-Board-134556500
Both are in the front control panel of the dryer.  Which one did you replace?
Domo!
