wobiii
KUIC18PNTS0 Clean light on, dumps water
9 posts in this topic
I have seen this problem a couple times but have never seen a fix for it. What happens is on power up the ice machine runs through the rinse cycle and then goes into ice production mode. . . for a few seconds, then drains the water from the troph. I've seen them with bad wiring connections at the troph sensor and low freon levels as well that I suspected. A buddy of mine says that he had one do this after taking the hoses loose off of the drain pump and then not getting it back on correctly. Can anyone explain what is going on to make the water empty out a few seconds into the ice production mode?
This last one that i'm fighting with has a full evap frost and no water in the troph when I got there and the clean/reset indicator light was red but i'm not sure what that really means. Is that light a timed light or an error light? The tech sheet was missing so I didn't put it into diag since I couldn't interpret the results other than the obvious pump running, fan running, "smart" valve letting water in (I won't use the word working here), compressor running. . .
Thank you for those. I still don't see an answer about the clean light coming on red even after the units have been  cleaned. Does anyone know if it's a generic long run failure code or something generated by the evap thermistor? Or is it just a timed dummy light? What makes the lights come on green, yellow, then finally red?
Thank  you kind master, but I have replaced the pump assembly that comes with the new water sensor and still have had no ice. I went back last week and disconnected the water sensor and have not heard back from the customer about this. I will keep you updated if I hear from them again. These are the type of people that will call a couple weeks later and tell you that it's still not working.
Went back and unplugged the water sensor and it seemed like it was going to run without dumping. . . . but then yep, called back. Still won't work. I'm thinking there is a freon leak now. Not really seeing anything else.
All indications point to the water level sensor.  I wonder if the evaporator thermistor is acting up.  Are you able to initiate the diagnostic mode?
Also check the pin connectors on both sides, both sensor and pump. Very prone to corrosion problems.
Yes I did run it through diag and everything said it was ok, The water sensor was changed with the pump and the connection didn't look bad. I've seen the bad ones that require new wiring harnesses with the green and the slime all over them so know what that looks like. Whenever I deal with these sensor connections I add a little dielectric grease to them to try to ensure a good contact and protect the terminals. I'm thinking it's got to be a sensor or freon issue from what I can tell. I think I've seen them before that have done similar that had freon leaks. I just don't understand the inputs that the machine is taking when that would cause it. I think I disconnected the evap thermistor but not sure at the moment. The evap never really forms any ice but may not have time and this thing is outside in the 90 deg heat and is being fed pretty warm water so it's kinda hard to tell and to deal with in August. Just keep thinking it worked before so should work again. It's been driving me nuts.
