Sears Ice Maker hanging up
1 reply to this topic
#1 tlbrouss
tlbrouss
  • 1 posts
Posted 07 January 2006 - 05:57 AM
The ice maker in my Sears Side By Side is not dumping it's ice. The motor in the ice maker makes grinding noises when the cubes are frozen. If I heat it up with a blow dryer, it dumps it load just fine. Is there a setting I can change, or should I just replace the unit?
#2 Pegi
Pegi
  • 13,120 posts
Posted 07 January 2006 - 06:54 AM
106.626636  Make sure the cubes are not so large they cannot be ejected...if they are normal size  might have to replace the IM or the module head..
