Sign in to follow this
Followers 0
James Hager
Frigidaire laundry center dryer FLSE60RGS2 white jumper on timer
7 posts in this topic
Frigidaire laundry center FLSE60RGS2 dryer timer 131062300 what is the white jumper called and can it be bought. It feels like rubber has black insulating rubber over connectors not wire inside but fiber like made of fine threads. Thanks
the little white rectangle ON / part of the Timer ?
looks to me like just part of the connector / insulator / wire positioner ...
Is there a problem with it ?
Not the resistor and it slipped out of the connector I put a new one on and when I started it got hot a little smoke. Will it run without?Also when I stripped it is when I saw the fiber.
You may be right Sohei I'll order one and try it only difference I see is color of the ends. Thanks
Not the resistor and it slipped out of the connector I put a new one on and when I started it got hot a little smoke. .
pictures ?
the white wire is one of the resistors, if its the one i think it is it wont advance in the auto dry cycle
Followers 0
