tatefamily1@gmail.com
Bosch / Siemens UltraSense plus Electric Dryer, Model WTXD8300US
40 posts in this topic
Hi!  Dryer is working, but started making sound as it is going around, sounds sort of like a belt on a car, when it is going bad, but not sure that's it.  Where do I begin?  Thank you from the bottom of my samurai-loving heart.   Rebecca
Also, I can't seem to find the manual, is that something I can download here?  :)
Thanks!  It actually sounds more like a metal on metal sound, but not grinding, more like a metal 'slipping' against metal, if that makes sense..  I can see from this manual how to take it apart, but can anyone recommend what I should do first, after that?
Question for samurai or one of his minions:  Is there any way to know if it's okay for me to keep using the dryer?  It is heating up etc but probably not a good idea, I know .... if it's the belt, and it breaks, then it just stops working, but if it's something else I figure I can ruin it worse if I keep using it.  I need to just go hang a clothesline -- if it would stop raining (14 days and counting, the ground is seriously squishy)
Could I pay someone to have a listen?  I could record it and send the file. I bet someone woudl know exactly what the problem is, just hearing this noise.  I might need to call a repairperson but they are hard to find for this dryer.  I fixed the washer myself (stupid pump, got the part from you all, worked great was just a pain taking it all apart).  I could figure this out but don't have days to spend zeroing in on it, am in Asheville NC, do you guys know anyone here?  Thank you!!!
Post a video to YouTube then give a link,
If you disassemble the top and front panel, you will probably find something stuck in the felt seals at the front front of the the tub our see wear on the seals and/or glides.
Best to repalce the front drum bulkhead I do believe.
http://www.repairclinic.com/PartDetail/Front-Bulkhead/241091/1103598
... Best to repalce the front drum bulkhead I do believe.
would that make the "sounds more like a metal on metal sound" ?
If there's something metal stuck in the felt rubbing against the drum. I've seen a dime causing that same sound on a Bosch dryer before. It could be something else, but from the sound I heard and prior experience is all I'm going by.
You guys are so helpful, thank you!  I will take it apart and see what I can see.  My husband tends to leave change in his pockets,  it's easy to miss dimes -- are you saying something can slide down in there?  It happened all of a sudden, it seems like wear on a part would show up and get worse?  Can it get into the machine via the lint filter opening, I wonder?
I'm not trying to say that for sure that's the problem, just letting you know that it's happened before. I'm also not saying to just order any parts, merely saying that when I've heard noises like that before it's been associated with the front drum bulkheads on the Bosch dryers. But it is easy enough to access that area to check for loose items that don't belong. Or for any wear, a sound like that will most likely be leaving some type of markings behind that will guide you in the right direction. If you look at the picture of the the part I linked to you'll notice a grey felt seal going around it. That's wear change seams to get caught, in between that seal and the drum along the front.
Now that you have stated the 'dime theory', that is what I hear ... hm.... :rolleyes:
That will be so funny, if you turn out to be right, to the penny :woot:
Especially if I can find that sucker without wrecking the felt (is this possible, do you think?) and having to get the new bulkead part at 150 bucks.  It really does sound like it's coming from there.
Question:  I have the control panel/fascia unscrewed and carefully laying to the side.
I can see how the six tabs fit into the washer, and that I need to lift that up to remove it.
The manual says to remove the belt first, before I slide the front panel off (under "Hints" ("to remove the tensino").
That is a whole 'nother ball of wax :yucky: (pull it out, take the back off, in order to remove belt, major effort, ugh).
Do I HAVE to take the belt off to access the front bulkhead?  If I need to I will, but am wondering why.
Can I break something if I don't remove the belt first, before I take the front panel off, or is that step more so I can manipulate the drum around more, to do whatever repairs the manual might think could be needed.  If I'm careful, etc., can I skip that step(s) (removing the belt).
Being cautious :rolleyes:   Thank you!  I will be a hero if I can fix this.
Can't proceed without someone walking me through this a little more.  Front panel seems ready to come off, but don't want to break anything.  Door is off.  Right side does not seem to want to come "up and off", I gave up (don't want to make things worse).  Anybody use Ask.com here?  Need someone who can hang in there with me, I have dryer partly apart but don't have enough knowledge to proceed and manual is confusing to ordinary consumer.  Ask.com wants 30 bucks, looks like they have a certified tech available, that is usually what I pay to beer fund (have new username here because old email address is defunct but have used before, with great success, on fridge and dishwasher).  but this time I'm stuck.
Don't think I need to take belt off, but am afraid to force front panel off without someone telling me it's okay to use a little force.  Both screws are out (on right, under hinge - took door off -- and on left, under little white plastic cover).  Left side seems to want to come "up and out".  right side is tough, may need more force, am worried there is something else I need to do first?  Maybe not.  Then, once that is off, what is the best way to look for the dime/get it out, or will it be obvious once front panel is off?  I guess these sound like dumb questions, but have no experience in this.
I  posted a topic w/YouTube link to sound dryer is making when it spins, a fellow very helpfully responded, sounds like a dime stuck in the felt.  Excellent!  Really does sound like that.  So helpful!!  Problem is, suggestion was to take off front panel, that it's easy to access that area.  Link to technical manual, so far so good.  Thank you!  But now, front panel won't seem to come off, I think I might see seems to be a screw somewhere near bottom of front panel I can't get to, but maybe it's just those plastic thingies being stubborn.  Dryer is apart, laundry everywhere, is now the next day and am stuck.  I went searching (I know you guys are busy) and found a post by Samurai that said he "pities the fool" that has to take off the front panel of Bosch dryers because you do have to take off the entire back to get the front off (the manual *seemed* to be saying that but not clear, the tech manuals assume you know what you are doing a little bit).  So don't know what to do now.  It really seems like there is just one screw holding it on, on the bottom right, and that if I could just get the panel off, I could find the dime (suspected) stuck in the felt.  PLEASE HELP!  Am wondering if its time to put it back together and call somebody, except we have trouble finding someone who works on these in our area.  Wah!
(second video, partially disassembled now)
(first video, has the sound in it) Edited by tatefamily1@gmail.com
This was the first thread, I think whoever was helping me is too busy now (which I can understand, not complaining, just have a dryer partially disassembled and stuck, don't know what to do now).  I paid 25 so far, is that enough for someone to look at this?
http://appliantology.org/topic/43303-bosch-siemens-ultrasense-plus-electric-dryer-model-wtxd8300us/
ps - I may not need to buy a part this time, but I have before (old email address, another username).  Dishwasher, washing machine.  When I get around to it will replace water line on Fridge.
Anybody know what this thing is?  Fell off.  Think we got the piece that was stuck in there, out, something fell when we jiggled it around.  This thing fell out later, don't know where it goes.
?ui=2&ik=778728cbbc&view=att&th=13ff7ea4
Right around the 17-18 second mark of the first video you will see a the blower wheel housing down in the front right corner, to take off the front there is a screw going into the front from that housing. You're correct that the way to get to the front is from the rear, everything comes out through the rear, unless you can reach the blower housing from above the unit.
I guess I wasn't clear, but you shouldn't have to disassemble he entire unit to get to that felt seal, now that it's partially loose you can check for visual damage to it or if something is lodged in the felt. The for the part was more for reference unless there is a lot of damage to it, then I suggest replacing the entire bulkhead not just the damaged parts. Then you would have to take there top, rear, console and drum out to properly remove the front entirely.
The image you posted isn't coming across on my computer. So I can't tell what it is
Thanks!  I think the felt is okay, and wiggling it around something fell out which may have been the problem, great job diagnosing it, thank you!  this is the other thing that fell out (much earlier)
?ui=2&ik=778728cbbc&view=att&th=13ff81b5
Can't see the image either.  I think there are screws near the bottom of the front panel on the side.  The piece could be the bracket that the screw secures to.  Those Bosch front panels are a bear.
looks like a spacer of some kind?
Found two screws, on the very bottom 'side' of the front panel, and those came out, but I think Spannerwrench is right that there is an additional screw from the housing that keeps the panel on tight from the front -- looks like we didn['t have to deal with getting the panel all the way off, just by wiggling it all around, I think the problem fell out.  Man oh man will we be checking pockets for CHANGE!  The technical manual does say, for almost everything, take the back off, I think next time I'll drag the thing out and just do that, probably worth the trouble just for access.  I posted another picture of the spare piece that fell off, can you guys see it now?
....  I posted another picture of the spare piece that fell off, can you guys see it now?
wasn't a valid link
(not the right url format)
does it appear when you click on it ?
I see you're not wearing any safety gloves while working on it. If you do venture into diassambling the unit from the rear, wear some gloves. These German brands have a partnership with Gillette and my hands and arms are have plenty of scars to prove it.
You seem to be doing well so far disassembling it. If you do take it apart from the rear, record it, and follow the instructions in the manual. But, by doing so, you'll be able to vacuum out the accumulated lint inside and also get a better understanding of the innards of your appliance. If you have already gotten the front back on and the noise has stopped I wouldn't worry about it.
The picture is still not showing up.
PS. I once got a $300.00 tip from a customer because I found her Engagement Ring in a Bosch Dryer. Also one time I found about $200.00 in change, mostly quarters, in the bottom of a Whirlpool Dryer that had almost no felt on the rear of the drum. It had such much change in it that the Thermal Cutout blew from no air flow. I don't know how none had gotten into the motor because it was about 3-4 inches in the bottom.
Things happen sometimes.
