Jill donato
No display on my kitchenaide superbra range KGRC707LBS0
3 posts in this topic
Oven heats and all buttons beep, but no digital display. I noticed the the display would periodically dim and brighten over the last couple months. Display just quit in the middle of baking, timer beep did go off when finished. Hoping this is an easy fix. Range is 10 years old.
... Oven heats and all buttons beep, but no digital display.
... I noticed the the display would periodically dim and brighten over the last couple months. .
... Hoping this is an easy fix.
easy ?
well, yes
http://www.repairclinic.com/referral.asp?R=154&N=941484
some users have had good luck replacing some of the Capacitors on the Control Board
Sister Jill, also check the cooling fan motor operation.  It's located below the oven cavity on the left side.  It, along with the thermostats under the control are responsible for keeping the control cool during oven use.
