Sign in to follow this
Followers 0
brm
samsung fridge hot to touch
6 posts in this topic
Samsung fridge Mod# rs2530bsh hot to touch in between door where gasket lays. i have the service man, on page 101 it shows that the hot pipe part of the compressor system runs there. I cheeked the evap coils they are frosting perfect, when I've seen this problem in past it has always been a system fault.
lacking a system fault I need to ask how do I fix this issue or if it can be fixed. the hot pipe is running about twice as hot as it should.
thank you
brm
i tryed to upload Samsung - Refrig - RS2530BSH - BWW - Ser Man. but it says its to big
I would see if your condensor fan in the back by the compressor is running. I've really only seen those go bad on side by side models. Be very careful because those motors can burn you if they are locked up. Try to spin the blade. If it is tight, then you need a motor
Yep. You may want to get a blade. The heat can make them brittle and are a pain to get off.
Thank you, that helps a lot.
Followers 0
