Sign in to follow this
Followers 0
homerhd
Kenmore gas dryer won't heat up
6 posts in this topic
I have a Kenmore gas dryer, lint trap in top right rear corner. Model 97274800. Tumbles fine but absolutely no heat. Worked a few days ago but no more. Please help.
... Model 97274800
would that be a 110.97274800 ?
check the white Thermal Fuse on the Blower Assembly
http://www.repairclinic.com/referral.asp?R=154&N=2986
if bad, then check and clean your Dryer Vents
Dryer Vent 4" diameter
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
Check / clean the Dryer Vent
$ 3.99 sometimes on sale for $ 2.99
1 person likes this
I took your advice and sure enough, the thermal fuse is no good. I jumped the leads on the fuse since it was bad so that I could check the igniter and the flame switch, both of which were ok. My vent is rigid, smooth, no screws and all connections inserting in the direction of the airflow so there's no edges to catch on. I even removed the blower box and cleaned that but it wasn't bad at all. Is it that unusual for a thermal fuse to blow when there in no restriction of air flow?
unusual, but could happen
check the Vent temperatures, and see how long a new Thermal Fuse lasts ..
The dryer is roughly 15 years old and this the first time the thermal fuse has been replaced. Is it possible that it could degrade over time? If nothing else, while I had it apart I gave everything a good cleaning, not that it was that bad.
Followers 0
