crbrew1
Roper gas dryer MOD# RGD4640YQ1
13 posts in this topic
Dryer starts when I push the start button and stops when I release it. Why?
Made by Whirlpool
If the Drum Motor is getting up to speed,
check to see if there's a build-up of Lint in it's Centrifugal Switch on the Motor.
Checked the motor, new unit no lint, dust or any other build up. What should I do now?
... Checked the motor, new unit
 it's a new Motor ?
symptoms indicate a problem with the Centrifugal Switch on the Motor
if this is a new model dryer, some of them had a relay in the start switch, i have seen a few go bad very shortly after purchase, within the first 6 months.
It's a new dryer, to replace the Centrifugal Switch would I have to buy a new motor? Or can I just replace the switch? Didn't see Centrifugal Switch in parts list?
yes
under warranty ?
OR the Motor may not be getting up to normal speed (dragging) ?
If you push and hold the start switch,does it keep running?
Yes, it keeps running when I push and hold the start button.
I took the drum off and started the motor and can see the Centrifugal Switch clicking on and when I let go of the start switch it still stops?
... can see the Centrifugal Switch clicking on and when I let go of the start switch it still stops?
still could be a bad Switch
(or wiring)
Black wire from Motor to Start Switch
Took the start switch off a working dryer and plugged it in and it worked, so I ordered a start switch. Just wish I had tried that first it would have saved me a lot of work... Thanks to ALL that Helped!!!
looking at the wiring diagram, a bad Start Switch wouldn't cause those symptoms
