Troubleshoot modern appliances with confidence…
Sign in to follow this
Followers 0
AlexM
Maytag Neptune Dryer Model# MDE5500AYW: Dryer dead, no control lights.
4 posts in this topic
About 6-months ago I worked on this dryer that was 'dead' and my notes indicate that I replaced a thermister P/N 3072080 and they dryer worked just fine in tell this week.
The customer called this week and it went 'dead' again this week.  I went back today and tested all limits and fuses.  I tested this same part and there was no continuity between terminals.  Should there be continuity on this part, my thought is yes because its a thermister, right?
I jumped the wires and tested the unit again and it still was 'dead'
Would jumping them allow the unit to run?
I checked the breaker panel and the unit was turned on at the panel.  I was unable to test for 240-volt at the terminal block because it will require serious effort to remove washer, then dryer to access back side.
Do these thermisters 'go bad' or will they shut down a unit?
post-71964-0-14853700-1374367202_thumb.j
post-71964-0-09013000-1374367233_thumb.j
post-71964-0-58381500-1374367259_thumb.j
post-71964-0-96037800-1374367298_thumb.j
Thermistors won't have "continuity", but they should have a high resistance reading.
If you can't get to the Dryer Cord Terminal Strip,
try this test:
set the Dryer to run an Air-Fluff / no-heat cycle.
then measure for 120v from each side of each Thermal device to chassis / ground
(not the Thermistor)
I can't get the controls to light up, so how will I know if I'm on a air fluff/no heat cycle?
may need to get to the Dryer Power Cord Terminal Strip
Followers 0
