Sign in to follow this
Followers 0
dryerman45
MAYTAG WASHER
10 posts in this topic
Dear Samurai's,
I have an maytag washer model # MAV6200AWW.The machine doesnt spin the clothes out .You have to ring them out yourself.I thought it might be the basket drive kit on this but the cust called back telling me its not spinning.Its an older model,so Iam not sure.Please help
SAMANERA
What happens during Spin ?
Washer Motor running, humming,
OR any unusual noises ?
  Sounds like it drained the water out which means the motor is running and belt turning. Remove the front panel, tilt the machine back and rotate the main drive pulley CCW by hand. This should release the brake and rotate the transmission and basket. If the transmission and basket are not rotating but you are able to rotate the pulley, have someone check to see if the agitator is going back and forth while you are rotating pulley CCW. If it is, the transmission is bad.
Eric
OK ,
it sits there and there is a humming noise.If you give it a start by hand it will get up to speed.It just wont do it by it self.
...  start by hand it will get up to speed.It just wont do it by it self.
including with an empty load ?
May be a bad contact in the Timer
May need to do some voltage tests at the Start Windings on the Washer Motor during Spin
http://appliantology.org/files/file/1076-maytag-washer-mav6200aww/
Thanks for the reply,
Yes I think it does it with an empty load as well.I have already replaced timer assy.Iam goin ther tommorow and will check voltages at motor and let you know what I find
SAMANERA
something between the Tub and Basket ?
  Does it drain the water out?
When you tip the washer back by about 45 degrees and look under it, can you rotate the big pully in the center by hand both clock wise and counter clock wise 4 or 5 turns?  IF you need to take the belt off the test this.
Thanks for all the replies,
I went to customers home and started a wash, advanced it to drain/spin and it will and does drain but basket just sits there.I take my hands and try to turn the basket  and its a little tough like there is a break on it but once i get it to move it starts to turn
by itself and spins up to speed.Before i did this and when it was in spin i looked underneath and the motor was working, the center pulley was turning, and of course the drain pump was working as well.Iam starting to think transmision.I dont know for sure.again I have replaced the timer and installed a basket drive kit for this unit.I think I have one more chance to get it right before Ill have to refund.
Thanks for any more ideas,
SAMANERA
Followers 0
