dryerman45
KITCHENAID OVEN ,MICROWAVE COMBO
11 posts in this topic
Hi Samurais,
I have an kitchenaid model# KEMS308SSS00.The oven doesnt broil.I checked the element and it is open so I think that should solve that problem.The microwave for this unit doesnt heat.If you run it it starts and runs for a bit then displays ''F1 E5''.It says replce micro.I think it means the inverter control.Will this repair this unit does anyone know
Thank you very much,
SAMANERA
F1 E5 CHECK MICROWAVE INVERTER
PROCEDURE: Before proceeding, press OFF, OFF, START to enter the Diagnostic mode and verify the error codes.
A. Unplug oven or disconnect power.
B. Replace microwave inverter.
C. Replace all parts and panels before operating.
D. Plug in oven or reconnect power.
E. Verify operation is normal. Press OFF, OFF, START to reenter the Diagnostic mode and complete checks.
KitchenAid Oven
KEMS308SSS00
Repair Part List - W10121005
Tech Sheet - 8304098A
http://appliantology.org/files/file/1087-kitchenaid-oven-kems308sss00/
Dear Master,
I went out to this call today and replaced the inverter and Iam still getting an ''F1 E5'' error after about 30 seconds.The only thing really left is the magnetron,or possible circiut board .Any ideas?
SAMANERA
Mag tube. I checked many with good readings but have cracked magnets which can cause that error.
Thanks for your reply.Iam going to replace magnetron.Will let you know the results
SAMANERA
I went back to this repair today and replaced magnetron still no heat and F1 E5 ERROR.Replaced microwave manager circuit then and same thing.I checked the switches for the door and all are ok.Checked microwave thermostat and cavity thermostat and they are reading continuity.Iam at a loss with this one.I could use some top notch expertise if possible
Thank you
SAMANERA
Thank you for the reply,
I was able to bring the original inverter from this job to the shop where I had an panasonic microwave that uses the same inverter.It works fine in the panasonic counter top micro so its safe to assume the original one in her kitchenaid combo is ok.So that leaves the magnetron and microwave manager.Iam going to take voltage measurments to see if the inverter is even gettin the voltage neede to run.I will let you know what I find.In the mean time if you have any other tips I would certainly appreciate it
Thank you,
SAMANERA
DEAR FELLOW SAMURAIS,
The new inverter I received turned out to be the problem.I went to customers house with a new invereter and replaced it.The original new one on close inspection had a hairline crack across  most of the traces.The problem I had was that I assumed the new part was ok,when it never was.This created a whole slew of additional part orders and trips.So I will be examining ever part especially electronic circuit very closely.Thanks for all your input
SAMANERA
Down here in Costa Rica I advise my customers to get rid of the inverters and buy a real mw if they need one.  Personally I don't use.  After the mw gets done with the food, do we really know what is left to eat?
Great job, dryerman!  Way to stick with it and git 'er done.  That was a great find on the hairline cracks on the board traces.  It's a good reminder to us all that boards can occasionally be bad out of the box.
