AlexM
Kitchenaid Trash Compactor-Model# KUCS03FTPA0: Is the switch to reverse motor attached?
8 posts in this topic
I successfully replaced a broken plastic sprocket that was attached to the drive shaft of the motor, runs the chain to the screw jacks.
I failed to test the unit with trash in it, only tested without trash, and the motor reversed at the bottom and the ram returned to the top.
Now my customer has called and there is trash inside and its making the same noise it made right before the plastic sprocket snapped in two.
My question is this: Is there a switch inside the motor that senses when the motor is slowing and changes the direction of the motor? Would the P/N be W10439651?
It appears that the drawer switch and top switch seem to work, would it make sense that its the motor switch that is defective?
Thanks in advance.
... Is there a switch inside the motor that senses when the motor is slowing and changes the direction of the motor?
the Switch inside the Motor is not for reversing
KitchenAid Trash Compactor
KUCS03FTPA0
KUCS03FTSS0
Repair Part List - W10118275
Use and Care Guide - 9872215
Tech Sheet - 9871923
http://appliantology.org/files/file/1088-kitchenaid-trash-compactor-kucs03ft/
Thanks for the info.
I briefly looked at the wiring diagram and still do not understand what switch senses the pressure of the ram and reverses the motor? Wouldn't it be the centrifigual switch on the motor?
,,, Wouldn't it be the centrifigual switch on the motor?
no
added 4322481 service seminar
Running—Going Down or Coming up
After the start switch is released and the ram moves down about one inch,
the top limit/directional switch changes position (the movement of the ram causes this action)
and maintains a circuit to the run windings of the motor.
The other internal switch of the top limit/directional switch positions itself to complete a circuit to the CCW start windings (ram up direction).
This condition is necessary when the ram stalls, it will change the direction of the ram.
1 person likes this
I've had a few of these compactors that have similar symptoms, Brother Alex.  If the top directional limit switch checks good, then check the actuator for the start switch at the bottom/right corner of the cabinet.  The actuators had a tendency to break and have been upgraded to a kit P/N W10342596.
The centrifugal switch IS indirectly related to the reversing function of the ram.
When the motor stalls it closes the start winds on the motor so that it can restart the up stoke, (basically motor stalling puts it back in the dead ready to start run position and with the top ram switch open the start winding polarity is reversed so that when the motor starts back up it is in the reverse running direction to raise the ram as opposed to starting in put ram down direction).
1 person likes this
thats what I kind of figured, Thanks!
... The centrifugal switch IS indirectly related to the reversing function of the ram.
OK, yes indirectly, but it doesn't reverse the Motor..
and if the Start Switch was bad, you would notice the Motor having trouble starting initially.
