Inglis Whirlpool dryer dead
47 replies to this topic
#41 papitohead
papitohead
  • 19 posts
  • Flavorite Brew:orange juice
Posted 13 August 2013 - 01:05 PM
The timer I have has different letters. Please review what I found:
First Plug:
A - Red (thick)
B - Blue
C - Black (thick)
H - Purple
Second Plug:
X - Orange
T - Black
F - White (with black stripe)
The little timer has two blacks in the little plug
I buy all my appliance parts right here with a one-year return policy!
#42 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 13 August 2013 - 01:38 PM
corrected model number
IED4400VQ1
http://Repair Part L...yer-ied4400vq1/
Timer
for reference
http://www.repaircli...R=154&N=1481701
#43 bigbuck
bigbuck
    Sōhei
  • Appliantologist
  • 236 posts
  • Flavorite Brew:Red Wine
Posted 13 August 2013 - 02:18 PM
I guess you have a wire diagram there. Does your timer motor work which is 230 volt motor on timer which is a very simple circuit to check if it don't then check why motor is not working on timer rather than main motor.Turn timer to time cycle 50 minutes.Check blue wire with power on to timer with voltmeter one probe to ground and the other to blue wire on timer.You should read 120 volts. If you don,t bad timer.Then leave probe on ground and check for voltage at what looks like orange wire on diagram and you should get 120 volts there.If not bad timer.This method is if timer motor is not working.It looks like you have the 230 volts from your other post.I don,t know if this will help you or not but it is a simple circuit which will rule out timer or not.But i think you will at some point come to the point were the timer will be bad thats what i think from reading all these post good luck.
#44 bigbuck
bigbuck
    Sōhei
  • Appliantologist
  • 236 posts
Posted 19 August 2013 - 08:46 AM
papitohead   Do you have any update on what you found on this dryer?
Edited by bigbuck, 19 August 2013 - 08:46 AM.
#45 papitohead
papitohead
  • 19 posts
Posted 26 August 2013 - 04:03 PM
Yes, I do have an update. We went camping and for the morning coffee times at camp, I decided to take the Timer with us to take apart and see what I would find since my gut feeling was the culprit of the problem. I did find that the bottom gear was laying flat at the bottom of the housing if you look at it from the top. I assembled it to what I believed was the place where it belonged but kept falling off. I then discovered that it was missing a little piece that acted like a dog to keep it in place. I decided that by making a plastic part to glue it next to it, it may just work. Well, it did, put every thing back together and she is running like if it was new.
Piece of plastic from a CD, free
super glue .... 3 for a $1 @ dollar store
Total expense ... $1
Satisfaction of another project solved..... priceless.
I hope some may benefit from this thread and thank all that tried to help.
I am not aware of how to post pics without uploading to a site, so if anyone can tell how to do it from my hard drive, I will then post them.
#46 RegUS_PatOff
  • 33,588 posts
Posted 26 August 2013 - 05:00 PM
... I am not aware of how to post pics without uploading to a site,
sorry, not for grasshoppers...
post to a site, then post links here ..
#47 bigbuck
bigbuck
    Sōhei
  • Appliantologist
  • 236 posts
Posted 26 August 2013 - 07:00 PM
Thanks for getting back to us.Its nice to know the end of a saga. :thanks:
#48 papitohead
papitohead
  • 19 posts
Posted 26 August 2013 - 07:59 PM
here are the pics:
