Learn how to be your own tech line…
Mustang64
Kenmore Washer (Direct-Drive) - intermittent spin problems until now - coupler looks ok
18 posts in this topic
I have a top load Kenmore Washer (Model # 11022632100) that I was having intermittent problems in the spin cycle, until today, - sometimes the clothes would be soaking wet, usually when it was a full, heavy load (towels, blankets, and so on). I figured it was the drive-coupler since I just replaced the lid switch about 3 or 4 months ago, along with the timer (although that was a mistake on my part) but after breaking down the machine and looking at the coupler I don't think that it is the coupler, which seems to be in great shape considering that I have 5 kids (3 of which are girls that change clothes 5 times a day!) and a dog so the washer is used frequently, well, closer to constantly.
if its not the coupler, the lid switch or the timer - where should I go from here?
the only thing that really stood out to me when I took out the motor and coupler is the presence of a black residue substance behind the motor mount plate as well as in the notch area where the coupler connects to the transmission assembly as well as on the assembly itself. It looks somewhat like coffee grounds or a powder but it is not granular at all. There is also a foam-type gasket, seal, or padding that is on the transmission assembly housing that I can easily move around with just my finger.
At this point I don't want to go out a spend money replacing parts unnecessarily but I am not sure when to go and/or what to look for. The other common issues for this type of machine are (1) the drive block, (2) the clutch, (3) the clutch band kit, (4) the motor, or (5) the bearing(s).
I'm not sure how to go about checking each of these possible problems, which order to check and how to verify if something really needs to be replaced.
Any suggestions?
... intermittent problems in the spin cycle, until today
... along with the timer (although that was a mistake on my part)
1) until today, what's it doing today ?
2) why was it a mistake ?
and, was it a new Timer ?
OR eBay ?
I would put the machine in empty and see if it spins. is motor running or is it locked up. If it does spin, can you easily stop it from spinning with the palm of your hand? You shouldn't be able to, and you run a good chance of getting hurt if the clutch is fine.
*I would put the machine into spin cycle, empty, and see if it spins
Edited by RussTech
OR eBay ?
today it stopped after washing 2 blankets (not very big or heavy - even when wet) it stopped spinning at all - no matter what cycle I tried
before today it would still spin most of the time, although we had quite using the heavy duty cycle about 6 months ago
the timer was new (expensive too) but I ended up switching it out even after I identified the lid switch as the culprit because I broke the little black plastic tab that goes in the back of the timer
I tried rerunning the a cycle with the blankets still in it - no spin
then took everything out and tried several different spin cycles - no spin
the agitator was working fine though - however I didn't pay much attention to it today because it had completed the wash and rinse cycles without a hitch
it doesn't spin during the spin cycle at all but how do I tell if the motor is running or locked-up, just by sound?
What about the black residue underneath - could there be a leak or something rubbing underneath?
... how do I tell if the motor is running or locked-up, just by sound?
yes
does it Pump the Water out after the Agitate cycle ?
yes
yes the water is pimped out after the agitate cycle
what happens after the water is Pumped out ?
continues to Pump for the rest of the Wash cycle ?
I haven't had any problems during the wash cycle  (water is in, when done water is pumped)
I haven't had issues with the pump during the rinse cycle
the problem is the Spin cycle - essentially
the Pump-out is a portion of the Spin cycle...
What happens after the water is actually Pumped out ?
Does it continue to Pump ?
OR does the Washer Motor "hum" OR stop completely ?
ok...i'll put the machine back together to test out exactly what the motor is or isn't doing and when they occur
Thanks for help thus far!
I am planning on an early start and I will post the results as soon as i can.
Thank you so very much for your help
good day everyone!
i put the washer back together this morning and tested it out (i replaced nothing, just cleaned everything up a bit and put it all back together)
here is what happened:
FIRST TEST
I tried starting the washer in a Spin Cycle
RESULTS:
- got nothing, absolutely nothing - no sound or action of any kind
SECOND TEST
I set the washer (empty) to a small load on a short 6-min normal wash and started it
RESULTS:
 - Wash Cycle
     - the water filled up normally and upon reaching the proper level the agitator turned on and worked as usual
     - the cycle proceeded as normal, the water was drained/pumped out without a problem, the motor turned on and remained on throughout
     - however the washer basket never moved
 - Rinse/Spin Cycle
     - again, the water filled normally and the agitator turned on and worked as usual
     - again, the water was drained/pumped out without a problem, the motor turned on and remained on throughout
     - however the washer basket never moved until towards the very end of the cycle, the basket did start to turn very slowly and appeared to be ramping up before stopping
Throughout the entire cycle the motor sounded normal during each cycle, i could hear the difference between when it should be draining, filling, agitating, rinsing, spinning however the basket simply didn't turn except for the one time
Could it still be the coupler even though the agitator still works?
Not sure how to proceed at this point...
(i took some pics of the washer when it was apart and i recorded each part of the test cycles today but can't seem to figure out how to upload them here)
  After it drains, the motor must pause to disengage the neutral drain. Does it pause after drain and then start again? Run it with the cabinet off and lid switch bypassed. Observe the clutch hub. In spin mode it should be spinning. If it isn't, the gearcase is bad assuming the motor is actually running (rotating). If it is spinning, the problem is with the basket drive. Either the brakes are sticking, the drive block is worn out, clothing stuck between the tubs...etc.
Eric
Eric
i did as you suggested and observed the clutch hub during the spin cycle and it is spinning without any problem
while observing the clutch hub i could see a some of the brake cam driver - should that be?
so it appears that it is either the clutch/brake cam driver or the drive block?
  Yes, the tab on the brake cam driver sticks down into the clutch hub to make contact with the tab on the clutch band. If the brake cam driver wasn't spinning, the clutch is slipping. It could just be a worn clutch. Take the agitator out and check the condition of the drive block. Make sure the grooves in the block are intact as well as the tabs on the spin tube. If your agitator has the fabric softener dispenser on it, you will need to take the clip and plastic washer off of the agitator shaft to see the top of the drive block.
Eric
do i need to take off the spanner nut off or is there another way to see the drive block?
i am down to the what u have in the picture and there is a lot of oil inside the agitator and the transmission drive - not sure if that is normal
  You don't have to take the tub nut off to see the top of the drive block. It's on in the picture. Clean the crud out so you can see it.
Eric
the drive block looks ok but the shaft seal/gasket inside that goes between the transmission and drive shaft (at the top) looks really bad
