AigulU
Viking vdsc 5364 dss
4 posts in this topic
Hi!
I have problem with viking range vdsc 5364 dss, when i turn on oven (bake or broilor or self cleaning) it works 3-5 sec and then turn off and light (oven) on the front panel flash 3 times. Can your help with this problem?
Thank you
It's depends on which oven you're using at the time.
The LED error codes are displayed on the control panel using the cycle lights. Refer to the chart below to determine
the type of error that is being displayed. These error codes are for the 48" left oven and for the griddle.
Cycle light flashing
Model Header error. 3 flashes, then 4 seconds OFF
The header error is the jumper wire on the control. It is used to tell the board what model it's on.
Edited by Spannerwrench
2 people like this
Just searching the site, looking for answers to a similar problem, the last reply refers to a chart of error codes, but it longer appears in the post.  Would it be possible to get it re-posted or added to the Downloads section?
Probably better off just requesting the manual in the Service Manual Requests forum.
