LG LSC23924ST
dcoyusa
  • dcoyusa
  • DurhamAppliance
I found out it has a button on the board like the LSR...... fridges have.
push 2x for forced defrost. I still would like the manual if someone has it.
The board and the info was on top of the fridge.
