LG WM2277HW Water does not shut off
11 replies to this topic
#1 sttevenb
sttevenb
  • 8 posts
  • Flavorite Brew:Hanger 21
Posted 25 July 2013 - 10:41 AM
I've just replaced a bad cold water activator and now the water will not shut off when the tub is full.
So far:
Good water pressure.
water contiues to flow when pause or stop is pressed.  Stops when unit is unplugged, and doesn't restart untill a new cycle is started.
Tube to level switch is clear.
Level switch reads 225/81 when soil level/ spin speed is pressed on front panel.
All wires and hoses replaced to proper location / orientation.
Thoughts?
Steve
#2 sttevenb
sttevenb
  • 8 posts
Posted 25 July 2013 - 10:53 AM
Update:
The water DOES shut off Pause or Stop is pushed.  It stops just as the door lock is unlocked.
#3 sttevenb
sttevenb
  • 8 posts
Posted 25 July 2013 - 10:58 AM
Further update:
Seems the center post of the new cold water activator is the source.  Water shuts off if that connection is pulled.  Bad part out of box?
#4 sttevenb
sttevenb
  • 8 posts
Posted 25 July 2013 - 11:05 AM
Further:
Just moved the center (#2 connection) to activate the other two connection.  Water flows through the activator.  New part is fine (probably).  #2 connection is staying "hot".
Where do I go from here?
Hopefully more troubleshooting!
Steve
#5 sttevenb
sttevenb
  • 8 posts
Posted 25 July 2013 - 11:14 AM
So final note:  The "main wash" connection on the cold water inlet is not shutting off.
Apologies for all the additional posts.
#6 sttevenb
sttevenb
  • 8 posts
Posted 25 July 2013 - 04:05 PM
This post is to replace my previous multi post about this issue.  The center connection on the cold water valve is not turning off.  Everything else works fine (if this connection is left disabled-with the exception of cold water fills during wash).
The service manual shows this wire Wht/blk going into the main board.
Thoughts?  Ideas?  Any help would be great.
Steve
    Shōgun
  • Master Samurai Tech
  • 30,622 posts
Posted 26 July 2013 - 05:43 AM
Have you checked to see if the center valve is always getting 120vac?  If it's not getting 120vac and it's letting water in all the time, it's a bad valve:  http://www.repaircli...Number=WM2277HW
Water-Inlet-Valve-5221ER1003A-01048774.j
#8 sttevenb
sttevenb
  • 8 posts
Posted 26 July 2013 - 10:41 AM
Thanks for the reply.  The issue is the main wash connection is ALWAYS getting 120 v, even during the spin only cycle.  IF that connection is plugged in, cold water contstantly folws regardless of cycle.   It seems to be a new problem since the cold water valve was replaced.
#9 PDuff
PDuff
  • 2,066 posts
Posted 26 July 2013 - 02:33 PM
Old valve may have zapped the main pcb.  Have you run the test mode?
    Shōgun
  • 30,622 posts
Posted 26 July 2013 - 02:36 PM
That's the only thing it could be!
Part link for the replacement PCB: http://www.repaircli...Number=WM2277HW
#11 sttevenb
sttevenb
  • 8 posts
Posted 26 July 2013 - 05:11 PM
I have during the troubleshooting of this.  Is there somethig specific I should look for?  The cold water main just ran all through the test mode, regardless of what other feature was being activated.
#12 Samurai Appliance Repair Man
    Shōgun
  • 30,622 posts
Posted 26 July 2013 - 09:11 PM
Look, the valve is controlled by the voltage from the main PCB. If the main PCB continues to put out voltage to the valve when it should not be, then is the main PCB is bad. This is not rocket science. If a thing is doing what it ain't awwta be doing, then it's a bad thang, and the fat lady done saying on that one.
