Joseph Strevens
Fisher & Paykel E372B
2 posts in this topic
My Fisher & Paykel E372B has started randomly beeping.
Every couple of days it starts beeping (without having opened the door).
The control panel has a flashing led behind the lower door panel. No other leds are flashing.
Opening and closing doors doesn't help.
Pressing the = button stops the beeping but the flashing led continues.
the fridge and freezer still feel about the right temp.
a list of fault codes/service manual would be much appreciated!
thank you!
its failed defrost
remove the control module from the rear of the unit next to the conpressor
remove the defrost connector brown wires
measure ohms , about 150 ohms
if you dont read anything then failed defrost element
if you do read 150 ohms then look at fans , particularly fridge fan in the bottom rear of the fridge behind the panel , looking for broken wire
