Frigidaire r/f
control part plug
18 replies to this topic
#1 dryerman45
dryerman45
    SAMANERA
  • Chief Appliantologist
  • 236 posts
  • Flavorite Brew:rootbeer
Posted 25 July 2013 - 10:07 PM
Dear Samurais,
I have a frigidaire REF/FREEZER Model# FRS6LF7FB6.The unit has a defrost problem.I checked the heater element and it is about 28 ohms therfore good.When I find that I usually replace bi-metal and control.I ordered control and bi- metal .The bi-metal is correct but the new controls plug is wrong.The harness in the refrigerator,i,e., the male end will not go into new control female end.The female end on the new control is backwards and upside down .wjere there suppose to be a square peg it is arched and vice versa.Anyway my distributor doent know what to do and the cust of course is running out of patience.Is there suppose to be a harness replacement with this or has electrolux made an error in the new control.IDK.If any of you guys or girls have access to tech help with electrolux I will trade for Tech help with a Samsung unit anytime.
Thank you
SAMNERA
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 25 July 2013 - 10:14 PM
... but the new controls plug is wrong.
part number ?
pictures ?
#3 dryerman45
dryerman45
    SAMANERA
  • 236 posts
Posted 27 July 2013 - 01:07 AM
Dear master here are the pics of the control assy
#4 dryerman45
dryerman45
    SAMANERA
  • 236 posts
Posted 27 July 2013 - 01:17 AM
sorry they wont upload
#5 MicaBay
MicaBay
    Master Roaster
  • PipPipPipPip
  • 900 posts
  • Flavorite Brew:Drifter Pale Ale
Posted 28 July 2013 - 09:56 AM
Is the new control orange, about the size of a deck of cards, and labeled ADC IV?
Is the The old one:
A.) white?
B.) without a plastic enclosure but the card deck size?
#6 RegUS_PatOff
  • 33,588 posts
Posted 28 July 2013 - 11:03 AM
upload them to some photo sharing website,
then post the links here
#7 dryerman45
dryerman45
    SAMANERA
  • 236 posts
Posted 28 July 2013 - 05:24 PM
Flikr.com/Photos/99578277@N08/9386192706.
Flikr.com/Photos/99578277@N08/9383415113
The first link is the new part,and the other the old .The part number that I get is 241739712.This is what comes up with the model #
FRS6LF7FB6.When you look at pictures you can see the difference.Thanks for your help
SAMANERA
#8 dryerman45
dryerman45
    SAMANERA
  • 236 posts
Posted 28 July 2013 - 06:40 PM
Attached File  9383415113_a31123f0a4.jpg   37.83KB   1 downloadsAttached File  9386192706_8d721c606a.jpg   44.06KB   1 downloads.Here are the pictures.
#9 MicaBay
MicaBay
    Master Roaster
  • PipPipPipPip
  • 900 posts
Posted 28 July 2013 - 07:40 PM
Looks like they are the same connector just 180 degrees from each other... That is odd.
#10 MicaBay
MicaBay
    Master Roaster
  • PipPipPipPip
  • 900 posts
Posted 28 July 2013 - 07:56 PM
Does your new part match the photo in this link?
http://www.repaircli...mber=FRS6LF7FB6
 It may have been you supplier sent you the wrong part
#11 dryerman45
dryerman45
    SAMANERA
  • 236 posts
Posted 28 July 2013 - 08:34 PM
The above pictures are the original on left with cigarette stains and the new one out of the box on right.My parts distributor cant give me an answer either.
#12 RegUS_PatOff
  • 33,588 posts
Posted 28 July 2013 - 08:46 PM
from Appliancepartspros:
When they made a change they flipped the connector over.
Tab for harness should be on bottom of board.
#13 MicaBay
MicaBay
    Master Roaster
  • PipPipPipPip
  • 900 posts
Posted 28 July 2013 - 09:14 PM
That was nice of them to share with the rest of the class.
#14 dryerman45
dryerman45
    SAMANERA
  • 236 posts
Posted 28 July 2013 - 10:04 PM
OK,
How do I use this part,or cant I
SAMANERA
#15 RegUS_PatOff
  • 33,588 posts
Posted 29 July 2013 - 01:49 AM
should be able to just turn the cable to match the Controller
#16 dryerman45
dryerman45
    SAMANERA
  • 236 posts
Posted 29 July 2013 - 09:12 PM
Dear Master,
Thank you for the tip.I was afraid of doing that because the clip on the harness wont match up,and thinking it will short something out.I will just simply  turn it upside down and connect it.
SAMANERA
#17 dryerman45
dryerman45
    SAMANERA
  • 236 posts
Posted 01 August 2013 - 08:47 PM
Dear Master,
I didnt have the nerve to make the control plug fit but I finally got the scoop on this conundrum.The control is correct if you order via the model #,however the new wire harness would have to be installed already.The part number for this repair is Part number: 5303918341
.This part number will get you the control and the new harness as well.Frigidaire made a boo boo
SAMANERA
#18 jkirksey1889
jkirksey1889
    Sōhei
  • 190 posts
Posted 24 May 2014 - 07:04 AM
You cannot simply turn the harness over, there is no room for the tab on the bottom.  I see this post is several months old and Frigidaire or whoever still hasn't solved the problem.  I'll assume dryerman is right and Part number: 5303918341
is the right part number.  We will see.
#19 Scottthewolf
Scottthewolf
    Senpai
  • 2,942 posts
Posted 26 May 2014 - 03:40 PM
Yes, that is the control to use when the harness pins don't line up or are upside down. It comes with a new harness.
Scott Wolf
