ycon
Newbie- bought a large open display fridge
7 posts in this topic
Hi,
So I went on on a whim and bought a commercial fridge for a business I'm starting. It's quite daunting!  :wacko:
I knew it was a risk when I bought it, but the buyer assured me the fridge had worked fine last time he used it (over a month ago). Even with delivery, the price was absurdly low.
It was transported from about 90km's away and it was stored upright. I have not turned it on.
I am not in a rush to have it all fixed up, as I have not opened my business yet.
It's the "IARP 180 Shelly" (link). Only difference is that my fridge has stainless steal above the front grills (others are while).
1. Basically- what kind of thing am I in for-should I get it serviced now? Does it just need a good clean up? Anything to look/listen out for?
2. Should I turn it on? It's in my yard (will protect with plastic), so maybe it's better to try at night when it's colder outside?
3. It will be used mainly during the day (12 hours) then be empty overnight. Is there any benefit in switching it off overnight (to save energy)? Or would it be pointless as it would have to 'cool' itself back down everyday?
I plan to 'renovate' it quite a bit- but I can give more details about that later
... transported from about 90km's away and it was stored upright. I have not turned it on.
... Is there any benefit in switching it off overnight (to save energy)?
... what kind of thing am I in for-should I get it serviced now?
... Anything to look/listen out for?
1) was it transported upright ? ...  if not, should be stored upright at least 24 hrs before running Compressor.
2) no, Fridges usually take 24 hrs or more to reach optimum temperature
3) I'm not sure.. we'll both have to do some research ..
3) plug it in, and after a few hours, check the frost pattern of the Evaporator Coils
post pictures ?
May be expensive to run ...
on-line info says
3.3 KWh / 24 hrs
which, at .10 per KWh, wound cost about $ 3 / day
OR $ 100 month
Thanks for the response-really appreciate it.
Yes-it was transported upright. I will switch it on shortly. What do the evaporator coils look like?
I've had a look-and it looks like it's from 1998. Is it too old? Or would this have a long life?
It does seem costly to run-which is why I'm considering switching it off overnight. But it end up being expense as the fridge would have to cool itself back down from a warm environment every day?
... What do the evaporator coils look like?
... would have to cool itself back down from a warm environment every day?
1) the "fins" that get cold
2) may take 24 hrs or more to reach Fridge temperature
So-I've finally turned it on. I'm very nervous.At first it made some noise (nothing sounding too unhealthy) and it was cooling!I left it about 10 minutes-and it had cooled (about 5 degrees) but there was no more noise.2 issues- it look like there's steam (smoke? No smell so hope not!). Does say its a "heater" on the white part and there is a coil. Is it heating the water in the reservior?Secondly-the temperture control screen isnt lit up. Do I need to pushSent from my GT-I9305 using Tapatalk 4 Beta
u4uqe8an.jpgeze2y8ej.jpgSent from my GT-I9305 using Tapatalk 4 Beta
Well what happened was it tripped the power board its on.
I plugged both cords (single phase) into it. Just testing it again and it's cooling very fast-from 20' to 8' in a few minutes.
