Samsung rf4287hars refrigerators
7 replies to this topic
#1 ronv10
ronv10
  • 4 posts
  • Flavorite Brew:coors
Posted 26 July 2013 - 11:00 AM
I am unable to despense ice from the door. The ice maker is working but I am unable to get it out.
#2 PDuff
PDuff
  • 2,034 posts
Posted 26 July 2013 - 12:12 PM
What happens when you press the lever?  Do you hear the auger motor running?  Make sure the control lock is not engaged.  Does water dispense when selected?
#3 ronv10
ronv10
  • 4 posts
Posted 26 July 2013 - 01:07 PM
If you push far enough water comes out.  No auger motor noise, control lock not engaged.
#4 ronv10
ronv10
  • 4 posts
Posted 30 July 2013 - 03:42 PM
Does anyone have any ideas about this problem? I think it is either the dispenser lever or the auger motor. Sure could use some help.
#5 Spannerwrench
Spannerwrench
    Mutsuhito
  • Master Appliantologist
  • PipPipPipPip
  • 900 posts
Posted 30 July 2013 - 05:35 PM
Take the dispenser cover off, something in the, probably plastic, is broken.
"Suds are not good"
"Occam's RAZOR 'the simplest answer is most often correct'"
#6 PDuff
PDuff
  • 2,034 posts
Posted 31 July 2013 - 10:05 AM
If the dispenser lever looks good, remove and check the auger motor.  Measure the resistance on the gray and black terminals.  If it shows open, replaced the motor.  Be sure to visually inspect the pins.
    Shōgun
  • Master Samurai Tech
  • 30,179 posts
Posted 31 July 2013 - 10:37 AM
Augur motor:  http://www.repaircli...mber=RF4287HARS
#8 ronv10
ronv10
  • 4 posts
Posted 31 July 2013 - 10:50 AM
Thanks everyone for all the help.
Ronv10
