Hotpoint Fridge
3 replies to this topic
#1 drbrain
drbrain
  • 4 posts
Posted 06 May 2005 - 04:43 PM
This is a Hotpoint fridge I inherited from the previous owners.  I can't find the model number (apologies for my ineptitude).  The freezer works fine, but the fridge is not staying cool anymore.  Also there is frost building up on the back of the inside compartment of the freezer. Could it be some kind of defrost problem, or am I flaunting my ignorance again?  How do I go about checking this out/repairing?
Please help oh wise ones.
#2 Fixum
Fixum
    Yamabushi
  • Master Appliantologist
  • 69 posts
Posted 06 May 2005 - 05:01 PM
if this fridge is of a few years , les sa over ten, and the frost that you see in the freezer on onide of the freezer only then i will say that you have a pencil drier that has burst and you need a compressor  old compressor number was wr87x345  one of the ge part numbers that i memorized:banana:
Fix On
#3 PK
PK
  • 19 posts
Posted 06 May 2005 - 05:23 PM
If you have a frost build up on the outside of the freezer wall, I would suspect you have a defrost problem.  Behind this wall you would probably find a wall of frost/ice blocking the air flow to the food compartment.  If you have a rotary compressor that is failing the whole box would be warming up.  Remove this back panel and see what the frost looks like.  If the whole evaperator is blocked with ice you will need to see what defrost components have failed.   Defrost timer, bi-metal, or defrost heater,or a combination of the three.   If you just have a ball of ice on the top corner of the evap., replace the box.  Let us know what you find when you have removed the panel.  If you have a defrost problem we will have to help you check the system.  Pegi
"Serving North Central Texas & Southern Oklahoma Since 1978"
#4 Fixum
Fixum
    Yamabushi
  • 69 posts
Posted 06 May 2005 - 05:32 PM
ge put the model number of the frige in two places years ago, in the fresh food section down  the interor wall abot a foot down from the top of the section, above the kick plate on the right side arround the door hinge, and on the very back of the unit on a white tag  ec. ctx18............
Fix On
