mallen7
Help replacing a refrigerator overload relay
6 posts in this topic
I am replacing a overload and relay for a Sears Kenmore refrigerator model: 106.52534101.    The original part number is 4sp1001.  The replacement part is : Whirlpool 4387835.  The original relay was connected at the number 1 and number 4 terminals. The new relay also has a number 1 and number 4 terminal but the terminals are a different size (#4 is much smaller).  Do you offer a wiring conversion kit for this?   Both the new and old relay had terminals marked 3 and 2 which had no connections.
Thanks for the reply. The link that you provided returns "part not found".  From what I can see in the picture in your post the only thing I might need would be that little wire connector. I get I could make one up if it's not available separately.
Kit number is  8201786................has all of the correct parts for your compressor size........
  ... The link that you provided returns "part not found".  .
link fixed
added instructions PDF
  The part # for that connector is 2310140.
