Kenmore 596.76502500 cools down then warms up
21 replies to this topic
#21 DurhamAppliance
    Sho' Nuff Chozin
  • 5,606 posts
Posted 30 July 2013 - 10:22 PM
the board you replaced uses the Utah software. However by Utah board I am referring to is the user interface controller (it also does the defrost function) . Maytag made two control boards, a Jazz board (two piece board joined by a ribbon and a Utah board (single longer piece) . Both have been problematic. You have the Utah version. It goes inside the ff section. part no W10207861. Get it from repairclinic and if it doesn't fix your problem, send it back. Then you have changed everything and probably have an overheating compressor or more than likely, a sealed system failure
www.DurhamApplianceThrift.com
#22 prarydreg
prarydreg
  • 12 posts
  • Flavorite Brew:Stella
Posted 31 July 2013 - 10:15 AM
Got It.  Thank You Everyone I appreciate the help.
