gipure
Replaced motor coupling and Broke again
7 posts in this topic
Hi, I have a Kenmore washer model 110.20722990 and it stop working, I replaced the motor coupling because it was broken. It worked great for 2 loads and it broke again. Can anyone suggest what could be wrong? I bought the coupling at a local part store. Thank you!
One of these? This is a genuine FSP part in a bag that says so. Notice the metal ring around the holes; gently tap the halves onto the motor and tranny shafts until the shaft is flush with the coupler ring; then it's on far enough;use something as a drift so you're tapping on the middle. I also swap the four grommets on the motor from top to bottom. The bottom ones bear more pressure due to the weight of the motor. There are other topics on this issue with other pearls of wisdom :wink:
http://www.repairclinic.com/PartDetail/Motor-Coupling/285753A/1195967
2 people like this
Usually the repeated breaking is caused by transmission failure, the gear case tries to spin and agitate at the same time. As it comes up to speed in spin, does it start making a loud rhythmic noise proportional to the increasing speed?
2 people like this
Warning, I bought a custom tool for removing those new metal couplers. It's called "coupler repair tool" and reliable parts sells them.
Without it, I had one transmission break because of all of the tapping with a screw driver it took to get a broken one out.  I actually had to buy the customer a new transmission!
Thanks for the heads up, Brother Joshua.  I'm guessing that was the new reinforced coupling that gave you the trouble?
Yes it was.
Recently I tried buying a generic coupler that looks just like the fsp part, and it broke after only 2 months.  Now perhaps the customer overloaded it, he said he put more sheets in the machine than he meant to.
But I think I'm going to use the FSP part from now on.
small parts like that you charge plenty & the profit margin IS there, not worth the hassle of aftermarket parts but Whirlpool has to come down on their prices.
I quit recommending them, wonder how many techs do the same.
Will also start a new thread on this. Went to a call on the new WLP  VM washer just as they came out, Had just taken the course armed with repair manual ran test, according to specs communication between motor & board, checked motor good, wiring harness good, must be board, RIGHT?
Because it was new,  part was factory order 2 weeks customer hated washer bought new & gave me said washer in witch it sat in my storage for 3 years.
Mothers 25 year old GE, old style, pump on top of clutch, trany had been leaking oil & finally crapped out.
SOOO since i now know it was the Actuator that was bad in that WLP i swapped them.
I don't think it washes good but on top of that it started HOWLING during spin.  That my friends is the transmission, $180.00 my price.  Think Ill go buy a bottom of line LG front load LOL.
Yes I know I will take it apart & see about the gear drive.
I still don't think they wash good, NO RECIRCULATING PUMP,  I looked at it with top open I think the wear & tear on clothes with no water is bad.  The front load action is better than the new HE top loads.
After ALL the advances in technology, new material , computers etc, we went back to the way our great grandma used to do down the river, same wash action as a front load, " Life Is Really A Circle."
