Joshua Scholar
Frigidaire top load washer bad bearing sound - transmission right?
13 posts in this topic
I have a customer with a Frigidaire laundry center that's Kenmore branded about 10 years old, model number 417.94862301
It works perfectly except for a loud bad-bearing sound when it spins.  I took it apart to replace the seal (which drips ever so slightly) and see if I could see what causes the noise.  even with the drum out and the seal out it makes the noise.  Dropping oil in the spin tube makes no difference, same with that middle part where the transmission bolts on.
There's a bearing that's part of the transmission in that middle part isn't there?
I told the customer it needs a new transmission and I'll get one tomorrow morning.
Was I right?
Reliable parts only has ONE transmission left.  Maybe they have more if there's an equivalent Frigidaire part instead of a Kenmore part.
Joshua Scholar
Kenmore/Sears doesn't make anything, this unit is made by Frigidaire.  Any parts looked up for this Kenmore unit and an exact same Frigidaire branded unit would come up with the same part numbers.
My main question was whether my diagnosis is right.
Transmissions are very common to go out in Frigidair TopLoaders. Almost more common than anything else it seems. Bad trans usually = condem... Especially on stack units.
Had a No drain situation a few weeks ago, sock in drain pump... After fiddling with the machine for about 45 mins we got the sock out and tested operation... Turns out the trans was shot also... Customer not happy we spent that much time just to condem.
Do you get the bad bearing sound in only one direction (ie spin or aggravate). Or both directions. How easily does it turn both directions when you turn the main pully by hand?
No sound is agitate.
I took out the tub so I got to spin just the tube by itself, still loud.
er no sound ON agitate.
I didn't try to make it agitate by hand though.
The tub only turns one direction though.
The conclusion was that it was the transmission.
I replaced the transmission and the seal and it's fixed.
It's odd that the specific transmission for that model is in such short supply.
Good job, Joshua!
How'd the tranny replacement go?  Did you replace anything else while you were in there, tub bearing, seal, etc?
The replacement went ok, but I seem to have lost my spring removal tool and reliable didn't have one...
So I had to ask the customer to help me when I took the inner and outer drum out and put it back in. On a stacked unit, there isn't space to pull the drum straight out, and it takes two hands to bend the springs enough to angle the shaft. Do you sell the spring removal/replacement tool?
And yes, I replaced the seal too.  the old one had shredded rubber at the top and was leaking a few drops each spin.
Don't know if you have enough room in these to use the 2"x4" metal electrical boxes in these but If you've never heard of or tried this.   You move tub as far as you can in the opposite direction of the spring you're removing and slip the electrical box over the extended spring to keep it extending and do that on each spring.
Need to have three of the electrical boxes and then all springs should be easy to remove since they will be all held in an extended position.
I was doing tub seal and transmission replacements on these laundry centers left and right while doing Frigidaire warranty service.  Not a whole lot of clearance to remove the inner tub.  Found it was easier to remove the bolts securing the tub to the trunnion and then remove.  When needing to remove the outer tub springs I just used a pair of linesman's pliers.  It was a chore but doable.  Used to be able to tell what day of the week it was by counting the cuts on my arms.
the trick i do on the laundry centers is never touch the springs, just take the belt off, take the pulley off, take the 2 bolts that hold the trans to the milkstool and pull the tub, basket trany out as one and work on it then, no need to fight to get the inner tub out with the dryer fighting you.
Kohai, that makes sense, though I did find and buy some spring removal tools today.  Actually what makes this tool magic is when you have to get the spring back in. It's not child's play but it is a lot easier.
