LG WM2487H has no power
8 replies to this topic
#1 Riezinger
Riezinger
  • 5 posts
  • Flavorite Brew:Bud lite
Posted 30 July 2013 - 07:36 PM
Hey guys, hoping for some guidance have the LG WM2487H steam washer worked fine for 4 or 5 years and then today just wouldn't turn on.
Checked breaker, no trip, then checked the power outlet, also still working. So then I searched online a bit and found this forum, so a similar topic, where to check the noise suppression filter, I seem to be getting 120v at the pink plug it seems to be okay. So assuming the main PCB ebr38163302 is bad?
I also read a post about spinning the drum manually and getting some life out of the display, which did not work for me.. I get nothing from that test.
We had some crazy power outages a couple days ago, but washer was doing fine the day after that, just now it decides to die. Could it be the display boards, or is the main board more common?
Or something else? Some sort of sensor?
I also have a little voltage tester that detects voltage right through the wire, and I was able to detect voltage with that right to the wiring that goes into the back of the display, so I'm doubting myself, but really just have no clue. Any help would be much appreciated!
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 30 July 2013 - 09:45 PM
... I seem to be getting 120v at the pink plug
120v measured between Red pin1 & Brown pin3 ?
#3 Riezinger
Riezinger
  • 5 posts
Posted 30 July 2013 - 10:12 PM
The top pin is either red or brown, the middle pin is green w/ yellow stripe, the bottom pin is blue. It get 120v between the top and bottom pins, so I would assume that is pin 1 & 3
    Shōgun
  • Master Samurai Tech
  • 31,244 posts
Posted 31 July 2013 - 06:42 AM
Post the complete model number, you dropped some characters at the end.
#5 Riezinger
Riezinger
  • 5 posts
Posted 31 July 2013 - 10:27 AM
WM2487HRMA
    Shōgun
  • 31,244 posts
Posted 31 July 2013 - 10:30 AM
On the main PCB, there's a red LED that should be on whenever there's power supplied to the washer.  If it's not on, then either it's not getting votlage voltage or the main PCB is bad.  http://www.repaircli...mber=WM2487HRMA
Main-Control-Board-EBR38163302-01061750.
#7 Riezinger
Riezinger
  • 5 posts
Posted 31 July 2013 - 06:15 PM
So it appears the led is out, had to unplug everything to find it, but hooked all back up and it's clearly not on. So this is a tell tell sign then?
    Shōgun
  • 31,244 posts
Posted 31 July 2013 - 06:33 PM
Indeed.  If you're getting 120vac between pins 1 and 3 on the noise filter, then the other possibilities are:
- bad on/off button, ohms test:
Pin 1(Yellow) to 2 (Red):
button not pressed:  open
button pressed: closed
Pin 1(Yellow) to 3(Black):
button not pressed: closed
button pressed: open
Pin 2 (Red) to 3(Black):
- bad 5-pin wire harness on display PCB (molex connector at the board as well as the connecting molex between the display PCB and the main PCB
- bad main PCB
#9 Riezinger
Riezinger
  • 5 posts
Posted 06 August 2013 - 09:58 PM
Just a quick update, I rolled the dice on a new pcb and that fixed it! Big thank you Mr Samurai!
