  • Announcements
Sign in to follow this
Followers 0
Joshua Scholar
Whirlpool dryer, good airflow but small flame
7 posts in this topic
I have a customer that I'm going to do a washer repair for on monday (replace the seal on a GE profile) but they also complained that their dryer, the common Whirlpool gas sort (with the blower in the back) is taking a long time to dry.
I replaced the coils on the dryer and noticed that the vent was totally unblocked and had good air flow, but when I look at the flame it seems awfully small and the amount of heat seemed less than normal.
Now I don't know of any adjustment for the flame nor any part to replace to make it bigger.  The gas valve seems totally open, so I'm at a loss for what to do.
When I go back tomorrow I'm going to see if there's anything blocking the nozzle, maybe a dead bug or something.
Can anyone think of anything?
LP ?
NG ?
set-up for wrong Gas ?
Has this Dryer ever worked OK at this location ?
how long ?
It's in an urban area so the gas is not tanks, it's the same as most dryers.
Lets assume it used to work, because if it never worked then this isn't a repair exactly.
They have a stove that works.
... Lets assume it used to work,
may have never worked for them at that location ..
They may have just bough a "used" LP Dryer
Hmm so if it's set for LP gas will the flame be smaller?
LP gas is higher pressure and the orifices are smaller.
So in other words the answer is YES,  If you run a dryer that is setup on LP gas on natural gas you will get a very small flame and less then 1/2 the required btu output.
Followers 0
