  • Announcements
Sign in to follow this
Followers 0
reeferman
Microwave, KitchenAid, KCMS185J/145J, STUCK DOOR
5 posts in this topic
Just received a call on this. Don't have a complete model number. Does anyone have a sensical approach to how to open a door with a broken latch/handle? Thank you..
Is there access through the inside of the keyboard/touchpad cavity? - Enough to get a screwdriver into a latch?
Slide a flexible card up between the touchpad and the door to lift the door latches to open the door for access. I have also seen where the plastic on the back of the touchpad where the button pivot engages has snapped, requiring a new touchpad.
Very cool trick, Brother Chat.  Gotta add that one to the arsenal.
Ooops! Forgot to leave some feedback on this. Slid a plastic card under the handle/latch area and opened the door. Part #5 had a broken tab/keeper that I glued and reinforced with epoxy. It's still working. Thanks for the info!
Followers 0
