Miele 2660 Service Manual / Service Mode access
2 replies to this topic
#1 tony35
tony35
  • 4 posts
Posted 06 August 2013 - 03:39 AM
Hi,
I need to enter service mode on the Miele 2660 Cafe Machine - to clear decalc mode. It was something like pressing both buttons while power up, then triple tap right button? Can't remember...
Also, the main issue is a faulty waste bin sensor - so I would really appreciate a service manual!
Thanks!
#2 Spannerwrench
Spannerwrench
    Mutsuhito
  • Master Appliantologist
  • PipPipPipPip
  • 956 posts
Posted 06 August 2013 - 05:49 AM
CVA 2650, CVA 2652, CVA 2660, and CVA 2662 Coffee Systems
https://www.dropbox....65x_266x_TI.pdf
"Suds are not good"
"Occam's RAZOR 'the simplest answer is most often correct'"
#3 tony35
tony35
  • 4 posts
Posted 06 August 2013 - 09:34 AM
Exactly what I wanted - thank you!
