icemaker won't stop filling. water overflows, no ice.
16 replies to this topic
#1 Springer
Springer
  • 10 posts
Posted 06 August 2013 - 03:21 PM
Hello.  I have a Frigidaire fridge, model FRT21LRGW5.  The icemaker is M1 SA8868.  The water fills the icemaker and overflows into the container.  It won't stop filling, and it won't make ice.  I had to turn off the water to the icemaker to stop it.  whassup?  thanks.
#2 Spannerwrench
Spannerwrench
    Mutsuhito
  • Master Appliantologist
  • 1,040 posts
Posted 06 August 2013 - 03:23 PM
Turn the water back on and unplug the frig and see if the water still flows.
"Suds are not good"
"Occam's RAZOR 'the simplest answer is most often correct'"
#3 DurhamAppliance
    Sho' Nuff Chozin
  • 5,770 posts
Posted 06 August 2013 - 04:22 PM
if the water still flows as per spannerwrench's suggestion, replace the valve. If the water stops flowing when the fridge is unplugged, replace the icemaker
www.DurhamApplianceThrift.com
#4 Springer
Springer
  • 10 posts
Posted 06 August 2013 - 07:56 PM
you guys are great! when i turned the water on and unpugged the fridge, the water did not flow.  However, let me clarify that the gears were not turning in either case (water off or on, unplugged or plugged).  I turned the gear, and it started going around, and the bar raised and lowered once or twice, but then the gears/bar stopped moving.  Does that sound like i need a new icemaker?  thanks again.
#5 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 06 August 2013 - 09:35 PM
... the bar raised and lowered once or twice,
twice ?
#6 Springer
Springer
  • 10 posts
Posted 06 August 2013 - 10:02 PM
yes.  the gears were not turning at all, so i turned it manually to give it a jumpstart, and it turned for a few minutes.  the bar went up and down (I think twice), and then it stopped moving.  should the gears be moving even if the water is turned off? thanks again!
#7 DurhamAppliance
    Sho' Nuff Chozin
  • 5,770 posts
Posted 07 August 2013 - 05:36 AM
Yes, the ice maker will still "harvest" without water. Sounds like your icemaker is constantly calling for water.... apparently the gears are jammed/ broken and the timing is off. Icemaker is kaput.
#8 Springer
Springer
  • 10 posts
Posted 07 August 2013 - 12:10 PM
that's what I was afraid of.  thanks for the verification!!!  I see where RepairClinic sells Frigidaire icemakers but how I know which one I need?
Thanks again!!!
#9 RegUS_PatOff
  • 33,588 posts
Posted 07 August 2013 - 12:31 PM
... Someone is selling one on ebay,
...  How do I know which one I need?
1) http://appliantology...amazon-or-ebay/
2) is there a part number on your IceMaker ?
post pictures (somewhere)
#10 Springer
Springer
  • 10 posts
Posted 13 August 2013 - 02:29 PM
Thanks for the info.  I am trying to disconnect the icemaker.  The screws are out, but I can't get it out.  The hose from the back of the fridge has what I think is a "harness" with four wires that goes into a plastic thing that looks like it plugs into the icemaker.  I took a picture, but I don't see where I can attach it here.
the part is model#M1 SA8868.  before and after the SA8868 is something that looks like .5U.  Under that it says 121499.
#11 Springer
Springer
  • 10 posts
Posted 13 August 2013 - 02:34 PM
what i'm trying to say is that I can't tell where the icemaker should detach from the hose.  i think the plastic thing with wires is part of the hose, and the plastic thing it goes into is part of the icemaker.  i have tried to wiggle them apart with a pliers, and they won't give.  am i doing it right?
#12 Spannerwrench
Spannerwrench
    Mutsuhito
  • 1,040 posts
Posted 13 August 2013 - 02:45 PM
Post a picture to a photo sharing website and then post a link here.
"Suds are not good"
#13 PDuff
PDuff
  • 2,062 posts
Posted 13 August 2013 - 03:19 PM
The wire harness for the icemaker has a plastic sheath and does not disconnect from the icemaker.  The connector plug at the other end may have been pushed through the evaporator cover.  Remove the center air tower and screws from the cover.  Pull the cover forward from the top but be careful, there's not a lot of slack in the wire harness going to the evaporator fan motor and icemaker.  Should be a molex plug for the entire harness that can be disconnected from the rear wall above the evaporator.  After that, all should be revealed.
#14 Springer
Springer
  • 10 posts
Posted 13 August 2013 - 03:36 PM
Here's the icemaker showing the front with the label, the side where the hose connects and the connector that I'm trying to disconnect.  Is this where it should disconnect?  What do I need to do to disconnect it?  thanks again!!
http://www1.snapfish..._NAME=snapfish/
#15 Springer
Springer
  • 10 posts
Posted 13 August 2013 - 04:14 PM
Dear PDuff,
I greatly appreciate your help, but I don't have a clue what to do. I am so sorry!!!   What is the evaporator cover?  Where is the center air tower?  What cover am I pulling forward from the top?  What is a molex plug?  Are you talking about the front part where the gears are?  There is that front piece with the gears, and there is the back piece with the "fingers" that the ice goes through.  The connector I took the picture of connects to the tube that goes out behind the freezer.  Thanks!!!!
#16 Springer
Springer
  • 10 posts
Posted 13 August 2013 - 04:28 PM
one more thing -  if you're telling me to unscrew the face plate, it says to disconnect the power cord before removing.  Does that mean unplug the refrigerator?
#17 Springer
Springer
  • 10 posts
Posted 14 August 2013 - 01:45 PM
Thanks to all who helped me.  I got the answers I needed.
