Amana refrig
5 replies to this topic
#1 hoagie1
hoagie1
  • 3 posts
Posted 06 May 2005 - 08:01 PM
I have an amana model # 36791 but everyone says that's not a model # so I have to give them the Mfg. # P1152601 ww. The condenser coils keep on icing up. I am using a blow dryer on them every three or four days. I thought it was the defrost thermistor, hoping it wasn't the defrost heater, so I replaced it, to no avail. Still doing it. I can't check for voltage at the heater because I can't put it into defrost mode. I tried the light switch thing, by switching it on and off five times. But that didn't work. Is there another method? Now you are going to say it's the circuit board. I don't think it is. I have 9 volts ac to the defrost heater. But I don't know if it is in the defrost mode or not. It does cycle, but doesn't defrost. I can't find anything on the energy saving switch, and it seems th be tied in to the defrost heater.  WHAT SHOULD I DO?
#2 nickfixit
nickfixit
  • 1,965 posts
Posted 07 May 2005 - 01:46 AM
That heater would need 120 volts ac to defrost. If your getting 9 volts, the relay on the defrost  control board is probably bad. I'm not familiar with this specific model, but many can be tested by using a mechanical defrost timer.
Check all the connections, and test to see if your heater is bad(got a meter?)
You may just have to buy youself a new defrost control
Nick
#3 hoagie1
hoagie1
  • 3 posts
Posted 07 May 2005 - 01:42 PM
Thanks for the reply. I do have a meter. I ohmed out the heater and got like 30 ohms so I think it is good. but the nine volts I was getting is not a true reading because It is not in defrost mode. Do you know how to put it in defrost mode? It might not be a bad idea to put a mechanical timer on it, is it easy to wire up?
  • 24,279 posts
Posted 08 May 2005 - 03:40 AM
Open the beer compartment door and press the light switch five times within six seconds to initiate defrost.  If the board does not respond, replace the board. See this page for more information.
#5 hoagie1
hoagie1
  • 3 posts
Posted 08 May 2005 - 08:01 AM
Thank you exaulted one. I was not convinced that it was the board, but when you said after hitting  the light switch five times if it does not respond, it is the board, you convinced me. I traced the problem to a relay on the board. I jumped it out and it is defrosting. I will replace the board and immediately go to the house of woes and await my punishment.
  • 24,279 posts
Posted 08 May 2005 - 09:53 AM
... and immediately go to the house of woes and await my punishment.
Punishment for what?  You found the problem.  Nice shootin', Hoss!  :armed:
