kes
Frigidaire FGHB2869LE1 icemaker problems
15 posts in this topic
My ice maker is not working. A technician came out and told me the ice maker control board is failing and the control arm control board is failing. I cant find a control arm control board anywhere on the internet. A sheet of ice forms in the back of the unit and sometimes locks the bin in place. It also makes a loud "clicking" sound. Im willing to replace the ice maker board but I need to find out about the clicking. The techician ran through the diagnostic but I cant find what the error codes mean . Any help would be appreciated
Edited by DurhamAppliance
corrected model number in title
FGHB2868LE1
... A sheet of ice forms in the back of the unit and sometimes locks the bin in place.
1) check that model number again
2) sheet of ice where .. on the back Wall inside the Freezer ?
OR inside the Ice Bin ?
Sorry FGHB2869LE1
The ice is on the back wall of the ice maker. Ive turned it off so there is no ice now but it buils up rapidly
Solid ice or crystalline rime ice?
Take a photo and upload it to Flicker or Picassa.  Post the link here.
Ice maker has been off for two weeks so theres no ice. It was solid ice. I tried to chip it out and couldnt.
post pictures when it returns
May be a bad water input Valve
Any external water Filter OR Reverse Osmosis Filter ?
Ill post pics when it comes back. External water filter but we have very hard water. Lots of calcium.
if the water filter is clogged at all,
and the pressure to the Fridge Water Valve is low pressure,
there sometimes isn't enough pressure to close the Fridge Water Valve and it seeps through
OR the Fridge Water Valve has particles (calcium / rust / etc)
preventing it's closure.
no water is coming from the outlet in the icemaker. This pic shows the hard water from the leakage in the front.I thought it was just the ice melting
5909221022737980481?authkey=CNT2juLNho6a
"link" is missing something
Arm
http://www.repairclinic.com/PartDetail/Ice-Level-Arm/241939901/1483653
IM Control
http://www.repairclinic.com/PartDetail/Main-Control-Board/5303918495/1795305?replacedManufacturerPartNumber=241956703
Dielectric grease for every connection
http://www.repairclinic.com/PartDetail/Super-lube-1-2-oz-t/5304485963/2690447
Foam tape seals to keep moisture out of the ice room
http://www.repairclinic.com/PartDetail/Gasket/241869708/1531414
Clean the ice room evaporator drain as well.
There's a good reason this ice maker wasn't in production long.
I'd like to find the engineer who came up with it and stick bamboo slits up his/her toenails!
Good call on the foam tape, Brother Spanner.  I'll usually shine a flashlight from the inside of the ice room and will find large gaps at the top front and right edges.  Simply sealing the gap cured many woes.  I believe they already have that engineer's head in a jar sitting in the middle of the Boardroom table at Electrolux.
Thanks for the replies. I need to figure out picasa. I posted the url in the right spot picasa wont show it because of permissions.
No, permissions would not prevent you from posting an image link.
If you would like to attach and download images, become an Apprentice: http://apprentice.appliantology.org/
the permissions are on the picasa side.
