Sign in to follow this
Followers 0
ApplianceDoctor
Frigidaire Refrigerator Moisture Collecting In Bottom Of Fresh Food
3 posts in this topic
I have Frigidaire refrigerator M # LGUB2642LE9 has freezer on bottom. Moisture is collecting in bottom of fresh food section. This particular unit also has an icemaker in fresh food section. I have found that freezer box that icemaker is installed in is forming some ice around edges of box along back wall of fresh food section. This ice is melting and running down back of wall. Has anyone encountered this before and knows what to do about it. I believe this may be what is causing the moisture to collect. Also need service manual for unit. Thanks
Appliance Doctor
Edited by ApplianceDoctor
If it's leaking water from the ice room, then you most likely need to replace the seal kit. Follow the instructions that come with the kit, failure to install properly will cause a leak.
http://www.repairclinic.com/PartDetail/Gasket/5303918578/2026405
... forming some ice around edges of box along back wall of fresh food section.
... what is causing the moisture to collect.
... Also need service manual for unit.
Frigidaire Fridge
LGUB2642LE9
240389646 tech sheets
5995620290 parts list & diagrams
http://appliantology.org/files/file/1132-frigidaire-fridge-lgub2642le9/
bad Door Gaskets ?
pictures ?
Followers 0
