Sign in to follow this
Followers 0
elmonducky
Whirlpool F.L. Washer WFC7500VW0
4 posts in this topic
No spin, has an F2 error code.
Whirlpool Washer
WFC7500VW0
Repair Part List - W10112250
Tech Sheet - 46197042905
http://appliantology.org/files/file/1133-whirlpool-washer-wfc7500vw0/
F02
OVERFLOW CONDITION
Overflow level has been reached, and last for more than 2 seconds.
In an overflow condition, the door remains locked and the drain pump runs constantly, and after 10 minutes,
door will be unlocked in order to cut off the valves power.
Then if overflow still happens, start pump again.
Turn off hot and cold water faucets and unplug the unit before servicing.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power, if water still flows into the washer, replace the water valve.
3. Check wire harness connections to the drain pump, pressure switch, water inlet value, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Check for drain pump failure.
6. Check the inlet valve for proper shut off.
7. Check the pressure switch for proper operation.
8. Remove hose from pressure switch. Dislodge any debris build up in the hose inside the outer tub.
Debris in side the hose will not allow the switch to sense a pressure change.
Interesting there is NO  water in the tub whatsoever!
things to check
Followers 0
