stuball
GE stackable won't drain or spin.
7 posts in this topic
Model # WSM2700dawww
Original problem when I started messing with the washer: would not drain. Struggled to spin, and of course shut off due to weight of load of water. Small drain holes under aggitator appeared to be clogged with soap residue. Cleaned out, and it would pump out water very slowely. Pump appeared to be weak, so I replaced it. Worked for a couple of weeks, then no pumping or spinning at all. Timer would quit at pump cycle and not advance. Lid switch appears to work as aggitator in wash cycle quits when lid is opened. Lid switch worked when spin cycle was still working. Safety latch for lid switch works as well.  My thoughts were that the timer might be the culprit. I cannot find any reference to pump or spin solenoid on this machine. No power to pump on pump cycle. No pump or spin on any of three dial settings (delicate, permanent press, regular).
Replaced timer. No change, i.e. no pump or spin. Aggitator works fine. Timer stops at drain cycle.
Arrrg. Not ready to give up!
... Model # WSM2700dawww
... Lid switch appears to work as aggitator in wash cycle quits when lid is opened.
1) GE WSM2700dawww made by Frigidaire
2) there's (2) Switches on the Lid Lock
check the Switches
from GE
http://www.repairclinic.com/referral.asp?R=154&N=947887
from Frigidaire
http://www.repairclinic.com/referral.asp?R=154&N=916791
Door-or-Lid-Latch-Assembly-134101800--01
I will try bypassing the lid switch (again) before I order. Why would the switch not work when the timer arrives at the drain and spin cycle, yet works fine in the wash cycle?
Thanks for any suggestions.
... Why would the switch not work when the timer arrives at the drain and spin cycle, yet works fine in the wash cycle?
... there's (2) Switches on the Lid Lock
Correct, the switch and the safety latch, built into one switch...hence the price of the switch. Tonight when I get home I will bypass the switch and see if there is any change.
I had to tell what happened for any who follow the "won't spin or drain" topics. There were two problems going on, which is what makes for a head scratcher. The first problem that occurred is that the machine would not drain fast enough, so when it went into the spin cycle, it would shut down to protect the motor. There were no clogs in the drain tubing, so I replaced the pump. It worked for about a week then quit draining and spinning. I bypassed the lid switch, even though the agitator worked fine, as well as the safety latch on the lid switch. Then the drain would start. Still not draining fast enough, so the spin cycle would shut down as the motor could not spin the tub with a lot of water in it. Back to square one.
So it hauled the machine outside and filled the tub with water. Took off the pump. It would not drain fast, even with the pump off. No clogs in hoses. Nothing to be seen looking up into the tub drain, so I assumed that the drain holes under the inner tub were clogged. This had happed before with soap residue, so I thought it might be happening again. I had forced water back into the tub with a hose before, and this had worked. But not this time. I was not going to try and pull the tub out to clean it as that would be a huge job, so in a last ditch attempt to find anything, I stuck my hand into the tub drain hole. I felt something fuzzy! So I grabbed the longest needle nose I could find and started pulling cloth lint pieces out. But there was something larger that I could not get to. Finally after about 45 minutes of pulling cloth pieces out, I was able to extract something the size of a NY City rat. It had moved around in the lower tub, so sometimes it drained and other times not. This made for very troublesome diagnosis. It ended up being a bra wire that had lots of lint matted around it. The bra wire slipped through one of the holes to get past the inner tub.
Good find!  Thanks for posting it.   :thumbsup:
