samsung fridge
1 reply to this topic
#1 reliml@att.net
reliml@att.net
  • 3 posts
  • Flavorite Brew:crown
Posted 11 August 2013 - 02:38 PM
samsung fridge mod # rf266aewp. icemaker not producing. replaced ice maker , still no ice . switched plugs on water valve to checkwater valve getting water when valve is triggered. help
#2 DurhamAppliance
    Sho' Nuff Chozin
  • 6,049 posts
Posted 11 August 2013 - 03:34 PM
check your freezer temps.... Should be not be more than 5F degrees for your ice maker to work. If your temps are okay and you are able to get water into the icemaker when you switched valve connections, then replace icemaker. Better yet, go through the test procedures in the service manual. http://appliantology...263-rf265-rf266
Edited by RegUS_PatOff, 11 August 2013 - 03:45 PM.
5F
www.DurhamApplianceThrift.com
