Ge monogram ZGU385NSM2SS pesky transformer
23 replies to this topic
#21 johntech
johntech
    Wigwagin Dragon
  • 491 posts
  • Flavorite Brew:Coke
Posted 13 August 2013 - 10:26 PM
Thanks a lot I found a short on that led harness
#22 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 13 August 2013 - 10:30 PM
on the Harness actual wires ?
repairable ?
What seemed to be the cause ?
pictures ?  before or after repair ?
#23 johntech
johntech
    Wigwagin Dragon
  • 491 posts
Posted 23 August 2013 - 11:11 AM
On a return trip I was not getting continuity with the gas knob turned on the appropriate pins coming from the led harness for the left front burner, I returned again with a shiny new transformer and the led harness which had to be special ordered. I installed everything double checked all of the connections and for 120v to the transformer, I buckled it all back up and plugged it in. I tried the left front burner and I got spark, it seemed weak sounding to me and the led was flickering, then I tried the next burner and got nothing, the rest were all dead, on top of that I started smelling an electrical burning smell it was the switches on top of the gas valve I unplugged and immediately checked my transformer and I had infinite on the primary windings. I checked my led harness and that checked out ok then I started checking the wires running from the transformer to the switch harness to ground and sure enough on that red wire I was getting 1.63 ohms to ground. Guess ill go back out with a new transformer and a switch harness, any other thoughts would be greatly appreciated.
#24 RegUS_PatOff
  • 33,588 posts
Posted 23 August 2013 - 11:27 AM
mechanical damage ?
pictures ?
http://www.repaircli...R=154&N=1262841
http://www.repaircli...R=154&N=1473713
WB18T10410 (not WB18T10381)
http://www.repaircli...R=154&N=1473712
Spark-Ignition-Switch-and-Harness-WB18T1
