MAH4000AWW,
FILLS AND WILL NOT TUMBLE
6 replies to this topic
#1 Magenta#90
Magenta#90
    Yamabushi
  • 83 posts
Posted 12 August 2013 - 07:41 PM
Fills with water then "on lights goes out" you have to press the start button again and fills with more water but no movement on the drum. possible bad motor (10 A fuse out maybe} is draining Ok. possible mad machine control or new conversion motor kit ?????????? thank you for any answer......
#2 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,905 posts
  • Flavorite Brew:Killians Red
Posted 12 August 2013 - 07:46 PM
Most of the time, a visual inspection of the MCU will reveal a blown component, and remove all doubt...but yes...it sounds like ya need the MCU/motor upgrade.
#3 lesguns
lesguns
  • Chief Appliantologist
  • 19 posts
Posted 12 August 2013 - 10:55 PM
possible bad start switch.
#4 PDuff
PDuff
  • 2,045 posts
Posted 13 August 2013 - 02:00 PM
Advance to timer to spin and press Start button.  Does the lock indicator light?  If not, check voltage at the door lock switch and continuity of the spin enable switch, both in the latch assy.  Check the inertia balance switch on the outer tub for continuity.  Examine the back of the machine control for visible damage to any of the resistors.  As Brother Kurtius advises, check the MCU first for damage.
    Shōgun
  • Master Samurai Tech
  • 30,396 posts
Posted 13 August 2013 - 04:45 PM
Upgraded motor and motor control board:  http://www.repaircli...mber=MAH4000AWW
#6 Magenta#90
Magenta#90
    Yamabushi
  • 83 posts
Posted 13 August 2013 - 09:37 PM
MCU  was bad, 2 or 3 burns on the control, we will install a new conversion kit. thanks.
    Shōgun
  • 30,396 posts
Posted 14 August 2013 - 07:05 AM
Thanks for letting is know!
