Caveman80
Kenmore he2
9 posts in this topic
Hi guys I have the washer kenmore he2 plus and I put it on rinse drain spin and I get no high speed spin. It goes through the cycle fine just no high speed spin. Any ideas?
model number ?
error codes?, if no digital display the tech sheet tells you how to read the lights to determine the code
Have to get the # and no codes or blinking lights.
I think if you select rinse/drain and spin and deselect 2nd rinse it should run a drain and spin only. Is there some motor movement? Does it start a slow spin and never ramp up to high spin? Is it draining properly? Could be a lot of things...shocks, motor control..drain pump. Find the tech sheet and try to run the test mode.
Yeah last time I watched it did everything fine but when it got to spin it would do it slow and not ramp up. I tried it in different settings and the same thing. I work 2 jobs so not much time to tinker till sat. Thanks for the replies every little bit helps.
Was it empty or was there a load?
Load
Ok I have an F-20 code but my clothes are wet and water is coming in the unit.
